Old 11-14-2010, 10:26 PM
miniman82's Avatar
First Light: 1952-2011
Director 21 resto begins....
This weekend, I began on what's sure to be a long resto on the CTC-4B chassis I hauled home from Indy. Why long? This set was apparently in operation in the same household from the time it was purchased until at least 1976, as evidenced by the repair tags left by RCA techs over the years. There are some ugly looking hack repairs, which will need undoing if it's ever gonna work again. CRT it had was a factory rebuilt 21AXP22, date code says 6543- which seems kinda odd. I would have thought they would've replaced it with a 21CYP22, but apparently the factory rebuilt metal tubes for a long time after they were 'out of service'.
First thing I did to the chassis was wipe most of the dust off, and test the tubes it had. All of them are good, so I won't have to worry about them. First thing I noticed was the power input jack was destroyed, so it will need to be replaced. Looked like the cord had melted to it, but the power trans ohms out fine (crossed fingers for the PTX). Next, I turned my attention to the HV cage. Looked good at first, but a second look revealed a burn under the horiz centering pot and a blown capacitor. Some past tech had wired the (replacement?) caps in totally wrong, which lead to the pot smoking. It will need to be replaced with a new one. Other than that, the horiz output transformer looks brand new so I hope the pot is the only trouble I have with the HV section.
Next, I pulled a few of the can caps and started restuffing them. They will have all new caps installed inside the old cans, then I'll reinstall the cardboard covers so it looks factory. After the rest of the power supply caps are replaced, I'm going to go ahead with a cursory run of the chassis to see what's alive at this point. I'll bring it up slow with the variac, and if nothing blows I'll probably recap the horizontal section so I can tell if HV is good to go.
More after next weekend!
Evolution...
miniman82's Avatar
More pics.
Evolution...
Old 11-15-2010, 12:20 AM
Some guys get to have all the fun!
Old 11-15-2010, 09:45 AM
This'll keep you off the streets for a while! Keep us up on progress. Do you know the CRT condition? Can lend you the tester if you need it (after Thanksgiving).
Old 11-15-2010, 10:58 AM
miniman82's Avatar
Yes, fun... that is, if you like long nights slaving over a hot soldering iron as I do!
Evolution...
Old 11-15-2010, 04:12 PM
ohohyodafarted's Avatar
Bob Galanter
It is always possible that you have a leak somwhere at the glass/metal union, however the work that John Folsom and I have done with leak testing suggests that the more likely point of leakage is the weld that joins the front and rear sections of the crt. In that case it is not likely that frit glass would be of much use in sealing the leak. Frit glass is used to seal the leaks on the glass/metal or glass/glass joints.
There is also the possibility that your 21AX has a leak on one of the leads at the gun end, but a weld leak is more likely. By the time they started making 21AX crt's, the technique of bonding glass to metal cone crt components, was very well perfected. It is likely that there was a small weld leak in the tube before RCA rebuilt it. RCA probably saw silver getters on the dud, and figured the dud was air tight, and so they went ahead and rebuilt it. The leak is so small that even today your getters are still silver, but it only takes a very tiny leak to let enough air into a crt to destroy it. After RCA rebuilt your tube it likely worked fine for quite a while until enough air got in to prevent it from working.
John Folsom and I are in the process of getting our used helium leak detector up and running which will allow us to pinpoint where the vacuum leaks are. Then we will need to proceed with a process to repair weld leaks. Progress has been slow, so don't hold your breath. Hopefully some day we will be able to repair the leakers and have them rebuilt.
ME http://AntiqueTvGuy.com
Old 11-15-2010, 06:49 PM
miniman82's Avatar
That's great news!
What's the deal with welding the funnel, is it a heat issue or the type of metal? And you're right, from what I can see there's still a getter there. I take it the leaks are too small to be found by traditional means (like dye inspection)?
Evolution...
Old 11-15-2010, 07:25 PM
Wayne: unfortunately, the CRT has a little air in it. I borrowed Mark's CR-70, and though the filaments light up without burning, the gun gets a blue/purple glow when HV is applied (I powered it with my CTC-9 chassis for a test). This means it will likely need to be sent off to RACS for the frit treatment, which means big bucks. In the meantime, I put a 21FJP22 in it. That might have to come back out though, because I noticed the HV button fouls the CRT support (possible arcing issue). A 21CYP22 would make a better fit, so I'll probably swap it out later on.
Here's what the 21AXP22 looks like.
Yep, sad to look at the thing and know it doesn't work. I have 2 like it, one which may have taken many years to develop a low level of air, and the other (in Bob's posession for now) that Scotty tried to rebuild, but showed air within a few days.
I am using the "rubber" shield from the 21AX to shield the HV button on the 21FB - can you slip that between your tube and your mounting hardware? Doesn't look elegant, but works, and can still be re-used if I get a good 21AX.
Old 11-15-2010, 08:33 PM
Bob Galanter
That's great news!
Making a vacuum tight weld is a very tricky and difficult thing to master. On the 21ax it is not so much the heat issue or the material, but making sure that the weld has no porosity. Proper welding takes very accurate temperature control so the heating and cooling of the molten metal is free from porosity. I had a very skilled welder try fixing a 21ax that we leak tested with John Yurkon, and it still leaked after we rewelded it. Originally we thought the material was Kovar, but after we tested it we found no Cobalt, so we now believe it is more likely some sort of nickel stainless. At some point we will probably need to have the metal analyzed so we can obtain the proper filler rod material for the welding processs.
BTW, Waynem your 21ax is in safe keeping :-) I will drag it to ETF next year for you to take home with you.
Old 11-15-2010, 09:40 PM
miniman82's Avatar
Interesting.
Can't detect the bad weld via x-ray inspecting either? We use x-ray and dye penetrant inspections in the military all the time to look at welds, check critical aluminum parts for stress cracks, ect.
Evolution...
Old 11-15-2010, 09:56 PM
jeyurkon's Avatar
jeyurkon jeyurkon is offline
Interesting.
It would show up the obvious big leaks, but not the nasty slow leaks. Air molecules are pretty small.
John
Old 11-15-2010, 10:36 PM
kbmuri's Avatar
kbmuri kbmuri is offline
...Some past tech had wired the (replacement?) caps in totally wrong, which led to the pot smoking.
Perhaps your cause and effect are inverted...
Do not attempt to adjust your set.
Old 11-16-2010, 12:00 AM
Red Raster's Avatar
Red Raster Red Raster is offline
Nice flyback, still looks raw and uncooked!.
Old 11-16-2010, 06:30 AM
miniman82's Avatar
That could very well be!
Red Raster: Yes, either it's a replacement or these things are easy on FB transformers. It looks brand new, only mark that I can see is some slightly melted wax on one side and it's from rectifier tube heat.
Evolution...
Old 11-21-2010, 11:05 PM
miniman82's Avatar
New updates, from this weekend of deer hunting/CTC-4 rebuilding!
Didn't bag any deer, though.
First I went about reinstalling the first round of restuffed power supply caps, which went well. So far all of the cardboard can covers have come off with little or no heat applied, so that's good. At this point I have both caps from the doubler portion done, and one of the others which is in the audio output section. Only 2 more multi-section caps to go, and the power supply is done. (3rd pic is the restuft caps.
I also cleaned the front of the chassis up, and the results are stunning! Under all the old cad plating there was nice shiny metal waiting to come out, so I went ahead and did the entire front where the controls are. First pic is the nasty state of the chassis before cleaning, second is a shot of the front after a good de-gunking.
Bonus: the tuner appears to be in working order, no stuck shafts or anything. Even the cords are in good shape, so it looks like a little lube and Deoxit will be all the tuner needs to come back to original glory.
Items for next week: finish the restuffing, do more work cleaning up the chassis, and probably test fire on the variac to see what's still alive!
Evolution...
