Old 12-21-2010, 11:16 AM
freakaftr8's Avatar
Convergence freak!
Talking CTC-9 from North Hills CA
Hey all
well I decided to test the CRT in this set last night. I pulled the back off and to my surprise all the tubes appear to be original!! The boards are in excellent condition and no burning. They are really clean and the whole chassis looks like it has extremely low use. The flyback is pristine!! OMG this set is like new surprisingly. The CRT tested dead so I cooked it for a few on 8v with my sencore. The emission came up in the blue then the red. Green was still almost non existent. So I let it go overnight. woke up this morning to a surprise. All 3 guns on the 21CYP22 tested great! So also yesterday I checked out the chassis and looked for shorts. Pulled he horiz output tube and brought up the set slowly light bulb stayed dim. Got sound and held there with no shorts. This morning replaced the HOT and crossed my fingers. Viola. Bright vivid picture on my BK color bar and alignment tester! Nice color and the fly is staying cool. Later this week I'm going to order the lytics for the power supply. I don't trust 1959 caps.
Old 12-21-2010, 11:22 AM
miniman82's Avatar
First Light: 1952-2011
Sounds like yours is at least as good as mine was, good stuff! Mine came up the same way, OG caps and all. Matter of fact, those were the only thing in the whole chassis I've changed, it's still on the original tube set (dates of '58).
Evolution...
Old 12-21-2010, 11:37 AM
freakaftr8's Avatar
Convergence freak!
Amazing! Now the CYP CRT is this the one with the frit seal?
Old 12-21-2010, 05:44 PM
miniman82's Avatar
All glass tubes use frit...
Evolution...
Old 12-21-2010, 07:14 PM
freakaftr8's Avatar
Convergence freak!
Lol. I know what I meant. Is this a glass and metal sealed CRT?
Old 12-21-2010, 07:20 PM
It's all glass, no leakage problems.
Old 12-21-2010, 07:31 PM
miniman82's Avatar
Only 21" metal one was the AXP, all others were all glass. Unless you count the leads for the gun, which I do not.
Evolution...
Old 12-21-2010, 07:38 PM
lots of pics please
Old 12-22-2010, 02:17 PM
freakaftr8's Avatar
Convergence freak!
I was doing some preliminary checks last night and the set went dead. Fly was not hot. No lights at all, acts like it's not plugged in, and i had no time to look into it yet. I was getting ready to pull the chassis and check HOT cathode current and write down filter cap values to order. So I will keep you guys updated. I have pics, just need to upload them.
Old 12-22-2010, 02:26 PM
hmmm sounds like a circuit breaker or on off swtich
Old 12-22-2010, 02:49 PM
freakaftr8's Avatar
Convergence freak!
No circuit breaker on this set. Just fuses. good call on the on off switch though. I will check it out tonight.
Old 12-22-2010, 07:14 PM
John Marinello's Avatar
<-- "Byron"
Check R193, 79 ohm cold, .49 ohm hot.
Old 12-22-2010, 08:00 PM
freakaftr8's Avatar
Convergence freak!
Don't have a SAMs on this one. Where is r193? This chassis is a CTC-9F
Old 12-22-2010, 09:17 PM
Chad Hauris's Avatar
I think this is an inrush current limiter in the primary of the power transformer going to the power line. If it opens up you will lose all power into the set. I have a set which is either a CTC-9 or 10 which has this same problem...worked when first tested but then completely lost power.
Chad Hauris
Old 12-22-2010, 09:48 PM
mbates14 mbates14 is offline
