Old 01-11-2011, 01:10 PM
rcafan rcafan is offline
Smile RCA channel Drum
Cought Me, I should have responded to that question, All the teeth on all the gears are good. I wish to proclaim that I am close to winning this battle using a number of ideas proclaimed in prior posts.
Very shortly --probably tomorrow, I will post the fix that worked for me.
Thanks, Neil
Old 01-11-2011, 08:51 PM
reeferman's Avatar
Let us know.
Old 01-12-2011, 12:50 PM
Smile Channel drum fix
The CTC20 channel indicator has been fixed.
Details are--the channel drum is mounted on a vertical stem that is
attached to a horizontal "L" bracket bolted to the front of the tuner mounting
frame.. by elongating the mounting hole on the L bracket toward the rear
(closer to the tuner) the drum can be moved back 1/16 " thereby engaging
with the drive gear on the tuner shaft.
The only other fixes to the set was replacing the Horiz osc and a small amount of vacuuming the inside, Pix tube was replaced in 83 by RCA and appears to have no hours on it. for a note of interest--the photographic finish on the metal cabinet looks great, would not know it from a foot away.
Thanks ALL, Neil
