Old 01-19-2011, 11:29 AM
chipper chipper is offline
Angry .00005/10,000v caps
I have a set that uses these bumble bee caps, any suggestions where I can find some replacements. thanks
Old 01-19-2011, 12:36 PM
That would be 50pF @ 10 kV. Are you sure it's not 500 pF ? Those are standard doorknob type caps use for TV HV filters and doublers.
Just Radios has 470pF @ 15kV http://www.justradios.com/orderform.html
Old 01-19-2011, 12:48 PM
correction
I had to many zeros, the correct value is .0005/10.000volts. used in a delco tv chassis
Old 01-19-2011, 01:31 PM
Are these used for the high voltage filters?
If so they can be replaced with a Ceramic cap and the value isn't too critical as long as it's equal or greater.
I used a couple .001@10k Ceramic discs for that purpose.
Mouser might have something that will work.
Old 01-19-2011, 01:49 PM
http://www.justradios.com/ sells a .00047/15KV tubular cap that I have used in TV high voltage circuits. On their cap order form, look under the 6KV caps.
Phil Nelson
Old 01-19-2011, 07:02 PM
Findm-Keepm's Avatar
Followin' the Rules...
Allied Electronics also carries the ASC caps in Phil's post - cheaper, and much quicker on the shipping than justradios.
$3.28 for Allied's 225-6085. I realized that's where they got them from when I got my last Allied order - same date and lot codes as justradios.
I also check out Allied's Clearance ("Excess Inventory") stuff - I got a lot of resistors and caps dirt cheap in early December from them. I'm set for now!
Cheers,
Brian
USN RET 22YRS (Avionics/Cal)
Old 01-20-2011, 09:57 PM
Hey thanks for the info; these caps are in my Delco tv-71 set.
