Old 05-01-2011, 09:16 PM
JB5pro JB5pro is offline
About these 15GP22's with vacuum and good filaments that may...
have air inside and thus soon to total ruin...
Is such equipment accessible or within budget to: Place CRT in total vacuum chamber that one can then drill tiny hole in safe place to evacuate completely and apply proper sealant to new evacuate hole and glass to metal seam all while under controlled vacuum?
I have not read of this but it sounds doable to me.
Old 05-01-2011, 10:34 PM
vintagecollect's Avatar
priceses dropping?
It's interesting to see no one's bidding yet. Are the prices for these sets dropping? Wrong color, unknown status of electronics, weird "fire sale" of set all of a sudden that's been sitting around for years. The only thing these people know is that they want $2K and need it moved in less than a week. Sounds like a dream to me.
1977 Zenith Chromacolor II
A Very Modern Zenith
Old 05-01-2011, 11:46 PM
Many people use esnipe or similar software to place a bid in the last few seconds of an auction.
The cabinet color should not be a huge negative. Toning lacquer is cheap.
I only mentioned it so that people don't get the idea this is a common cabinet color (or good refinishing practice). If you're going to refinish a cabinet, why not make it look authentic? In the overhead view, looking down at the CRT, you can see the original color on the inside edge.
Phil Nelson
Old 05-02-2011, 12:14 AM
Old 05-02-2011, 12:17 AM
prices dropping?
talked to a contact today about the ct100. They were honest when talking about the set.At some point, one tube was replaced w/ a diode. Turning on the set recently caused the diode to melt and liquify. A proper replacement tube was used and no HV present. The FBT has bad arcing out of the side of it now to the HV reg. tube. IS there anyone with ANY spare FBT for these sets? New or used.
Old 05-02-2011, 11:00 AM
kx250rider's Avatar
REAL TVs have TUBES!
So the custom order CT-100MBO would have been much lighter than the lighter set at ETF?
Yes... It was "limed oak" color (basically painted yellowish off-white with tan grain filler in the mahogany wood). The knobs and pencil box were light beige in stead of the brownish reddish color on the familiar CT-100s.
Charles
Old 05-02-2011, 12:57 PM
TubeType's Avatar
TubeType TubeType is offline
TubeType Sets
My Two Cents
For the record keepers, the chassis serial number is B1111566.
Caretaker: RCA CT-100
Terry's Tube-Type Sets
Old 05-03-2011, 12:36 PM
It looks to me like it was striped of the original toner finish, and then clear coated over in its natural wood. Not original, but not too bad looking. Hopefully it's not a poly finish.
Old 05-04-2011, 11:42 AM
TubeType's Avatar
TubeType Sets
Also, the cabinet and lid number is 472. The control panel insert number to follow.
Old 05-05-2011, 11:35 AM
miniman82's Avatar
First Light: 1952-2011
Bump!
2.5 hours left, and no takers!
Evolution...
Old 05-05-2011, 11:47 AM
Tom Albrecht's Avatar
What is the slightly darker rectangular area on the front panel under the control door?
Old 05-05-2011, 11:58 AM
It's a snap-out wooden panel, which conceals more controls. If you scroll down (and down, and down) in this article, you can see it in various pics.
http://antiqueradio.org/RCACT-100Television.htm
Phil Nelson
Old 05-05-2011, 12:06 PM
David Roper's Avatar
console lover
Carnac says it's 472.
tvontheporch.com
Old 05-05-2011, 02:02 PM
miniman82's Avatar
Went bidless.
I sent him an email, let's see if there is a response.
Evolution...
Old 05-05-2011, 02:12 PM
rcafan rcafan is offline
ct100 observation
Probably nothing?? look at the ballast resistor just above the area
where the cover is tilted down,there is a black spot.
Possible short????
