Old 05-19-2011, 07:04 AM
Reece's Avatar
Reece Reece is offline
You could make your own,
http://antiqueradios.com/forums/view...er=asc&start=0
or order one from various sources, here's one:
http://jmpalm.home.mindspring.com/
Reece
Old 05-19-2011, 05:13 PM
I believe that the second set of knobs were originaly used on postwar RCA TVs as they look like the ones on my 9T246. ARC had an article on replicating those plastic dial glasses a few months to a year back that also might be helpfull.
Old 05-21-2011, 01:57 PM
peverett peverett is offline
You might try this website for a replacement dial cover:
I have had good luck with his covers.
Old 05-21-2011, 03:02 PM
Buzzsaaw's Avatar
Buzzsaaw Buzzsaaw is offline
Smile Further more
Thanks for the info guys..
The caps are on order but I had to take thing apart a bit.
An overall view
More
And some more
Speaker with vibration proof screw installed. The wire coming from the speaker coil was broken.
Cleaned up a bit and closer view.
Front view.
Top side
Tuning Capacitor and it's Grommets. They look awfully big? Right?
With the Grommets removed, notice the double hole. Is this normal? Also in that picture, the RF antenna coil is visible with no support for the coil other than the large Gage wire it's soldered to.
A few more days and it will be playing music.
Buzz
______________________
Buzzsaaw
Sunlitedreams.com
Old 05-22-2011, 07:00 AM
Reece's Avatar
That piggy-back volume control is a replacement: notice one gang is not used. I suspect the little floating-in-air coil is the oscillator coil, not unusual for it to hover. The double holes for the tuning cap if punched may indicate the mfr. wanted to use the chassis for two different cabinets or with two different brands of caps, to make the cap line up with the cabinet.
Reece
Old 05-22-2011, 07:51 AM
Buzzsaaw's Avatar
Cool double hole
Yup... saving money to make money.
I have a replacement pot for that double ganged pot/switch. Notice the 3 holes in the front of the chassis. I've seen some other radios with 3 controls out the front. Perhaps a tone control or am/fm switch?
The "do all chassis".. good idea.
I'll have to find some replacement grommets. Notice the 3 flat washers and only one inside " bell " shaped washer. I think this radio has been worked on a bit before. Of course the speaker work shows this. At least the case is fine.
Buzz
Buzzsaaw
Sunlitedreams.com
Old 05-22-2011, 05:59 PM
Buzzsaaw's Avatar
Red face CardBoard Dial backplate
Got a Question...
The cardboard dial face is warped. In the top area where the dial lamp clipped into the dial face really tweeked the cardboard.
How's the best way to straighten that out so it stays? Maybe use some starch in water and a Dry Iron to make it ridged again?
Buzz
Buzzsaaw
Sunlitedreams.com
Old 05-23-2011, 05:05 PM
Reece's Avatar
Without a picture it's hard to say about straightening the dial face, but if it has a foil face on cardboard you could do this: thoroughly dampen the cardboard back in the affected area. Then clamp the dial between pieces of wood, using a piece of waxed paper on the front foil side. Leave it a couple of days to dry. It should straighten out. Then you could glue a thin layer of wood, 1/16" or 1/8" thick (hobby store like Michael's) to the back and clamp to dry. I've straightened cardboard rear covers like this and they came out fine, even without reinforcing with anything else.
Reece
Old 05-23-2011, 06:54 PM
Buzzsaaw's Avatar
Smile Warp 1
Hi Reece,
Thanks.
The dial is cardboard and a real nice color (gold) with ink transfer lettering. :
and the Edge on view:
I suppose I shouldn't get too much water or moisture on the dial face but the back might be ok. Right?
I'll only get one chance with this and I don't want to ruin it of course. I did a scan of it and the color isn't so hot without using Photoshop's tools, but I could reproduce one if needed. I like your idea about backing it up with thin wood. I think there's enough clearance between the back of the Dial face and the front of the dial pully. I'll do some checking. Looks like the dial lamp did a job on this. Even the clear plastic dial cover is warpped where the dial lamp came close to it.
Thanks again and I really appreciate the help you guys.
Buzz
Buzzsaaw
Sunlitedreams.com
Old 05-24-2011, 07:13 AM
Reece's Avatar
I think I'd dampen the whole back of that one. Let it sit a few minutes for the dampness to go in. Then when you weight it or clamp it, go easy in the beginning so it doesn't crack, go little by little until weighted flat in half an hour.
Reece
Old 11-22-2011, 02:55 PM
Buzzsaaw's Avatar
Finally, I'm getting back to this little radio.
I found one thing kinda funny and haven't been able to see this in any of the AA5 schematics. On the 12SQ7 tube (Det ckt) the two diodes in the detection ckt are tied together. ie Pin 4 and 5 are tied together. Pin 4 is going to the transformer (IF) and pin 5 is tied to the AGC ckt as per the drawing, but strapped together at the tube socket.
Anyone ever see this?
Originally Posted by wa2ise View Post
The circuit will most likely be a hybrid of these:
Many Thanks Guys
Buzzsaaw
Sunlitedreams.com
Old 11-22-2011, 03:15 PM
Buzzsaaw's Avatar
I looked
Looking at the posting " GE L-600 " by Hi Fi Canada I found my answer in one of the replies he got on his tube placement.
[URL=http://www.nostalgiaair.org/PagesByModel/190/M0008190.pdf [/URL]
I'm not sure the above URL worked.. but it can be seen that pins 4 and 5 on the 12SQ7 are tied together.
This drawing may be closer to what I actually have in the radio minus the multi-band selection scheme in the front end.
Except.. Pin 5 is still tied to the AGC ckt.. and not like that drawing of the GE L-660.
Too bad I can't find a Lang AA5 radio schematic. Puzzles are fun with these old radio ckts.
Buzzsaaw
Sunlitedreams.com
