Old 09-11-2011, 02:47 PM
Kamakiri's Avatar
Kamakiri Kamakiri is offline
Flyback on my CTC-12...HELP!!!!
Okay, I'm about 80% done with changing the flyback on my CTC-12....and of course the new fly isn't exactly plug and play, so I had to transfer resistors and caps from the bad one.
I did all of the wiring successfully, except for two things. One is a thick blue wire running underneath the chassis to pin 9 on the picture tube. The second is a 47 meg resistor. Both are attached to the 4 pin junction on the flyback.
I redid everything else correctly, but like a ham fisted retard, somehow I lost the positions of where both of these should go.
Please help, it's all apart on my living room floor!
Old 09-11-2011, 03:14 PM
ctc17 ctc17 is offline
Pin 5 of the focus rect 1V2 should connect to a 1 meg 2 watt resistor as well as one of the filament leads. The other side of the 1 meg resistor should connect to that blue wire.
Pin 4, the other filament lead should connect to the 47meg resistor and the disc cap that goes to the focus coil, the other side of the 47 meg goes to the vert circuit.
Maybe I misunderstood your question..?
Old 09-11-2011, 03:49 PM
Kamakiri's Avatar
I think I got it. We'll see.....
Incidentally, I ended up finding the schematics here:
http://boxcarcabin.com/rcaschematics.html
Old 09-11-2011, 04:21 PM
Yep thats my site. PM me contact and ill send you the good one
Old 09-13-2011, 08:46 AM
Kamakiri's Avatar
It didn't go so well
Nothing fried, but nothing else happened either. No raster, no sound, no nuttin. Back to the drawing board.....
Old 09-13-2011, 09:25 AM
what was the original problem that pointed you to replacing the fly?
if you disconnect the plate cap from the horz out do you get 400vdc at the connector (the wire not the plate cap of the tube)?
Old 09-13-2011, 10:25 AM
Zenith26kc20's Avatar
Check for a dead damper tube if there is no B+ on the plate cap of the horizontal output. A bad flyback could have killed it. If it's good, check for 390 volts on pin five of the damper.
Old 09-15-2011, 09:53 AM
Kamakiri's Avatar
I bought the set from grimer, needing a flyback. In retrospect, I should have powered the set up first and saw how bad the corona was (it had some burn marks) and tried to reseal it. Since it came with a NOS fly, I figured might as well swap it out. I'll pick up on the set when the snow starts to fly
