Old 09-21-2011, 08:47 PM
stusnyder's Avatar
stewart - warner 300
I picked this up at kutztown for 8 bucks, clean and all there except for the tubes. Very good condition set. I hooked up a speaker, put in a set of known good 201's, hooked up the battery eliminator, and was greeted with static.
Could not manage to tune in a station. I assume the center dial is the "coarse" tuning and the others are "fine " tuning. Anybody have any pointers how to tune these?
Old 09-21-2011, 09:02 PM
I believe that one should rotate all knobs in unison so they stay at about the same position then when a signal is heard each one is tweaked seperatly for maximum volume. But what do I know, I've never owned a TRF set that did not have the three tuning caps connected together mechanically. So this procedure is merely a guess.
Old 09-21-2011, 09:39 PM
truetone36's Avatar
electronics packrat
have you tried hooking up an antenna? IIRC, these sets need an external antenna to pick up much.
Old 09-22-2011, 03:51 AM
stusnyder's Avatar
Yep, got a 100 foot long longwire outside...
Old 09-22-2011, 06:42 AM
Reece's Avatar
Reece Reece is offline
Electronic M is right, you need to keep the three tuning caps in about the same position. Put a strong local station on another radio and look at how the tuning cap is meshed. Then put the three tuning caps on the Stewart Warner in the same position and try. Each will have to be tweaked to max the signal.
This hassle is why the mfrs. worked so hard to get one-knob tuning!
Reece
Old 09-22-2011, 04:12 PM
stusnyder's Avatar
I'll try it tonight, thanks for the tips!
Old 09-23-2011, 03:47 AM
stusnyder's Avatar
I checked it out more last night and it seems like one of the transformers is not getting power to it.
Old 09-23-2011, 09:19 AM
Sometimes the rosin in the solder used back then was a bit corrosive on the fine copper wire. Sometimes careful resoldering to bridge the break might fix it.
Old 09-23-2011, 08:01 PM
stusnyder's Avatar
Worked on it tonight, I do have power in and out both transformers. Checked out everything else and did not find anything obvious. 2 capacitors in entire radio. No value listed on them or in schematic. Anyone know what value are these?
Old 09-24-2011, 07:28 PM
leadlike's Avatar
leadlike leadlike is offline
Caps are typically 1 or 2 mfd, rated for a couple hundred volts DC. On these 20s radios, typically you'll find the interstage transformers open. There are replacements available-I believe AES sells just the bobbin and windings so you can use parts from your old tf to keep things looking original. You can also bypass your tfs with some common value caps and resistors. I think the Philco repair website has a how to on that.
Old 09-24-2011, 10:03 PM
stusnyder's Avatar
I did some checking on it tonight, it seems like one transformer is open.
Old 09-25-2011, 04:42 PM
Somewheres on the web I saw an article on using of all things a ringer from an old Ma Bell telephone as a replacement for such transformers.
Old 09-25-2011, 08:16 PM
stusnyder's Avatar
Antique radios have replacment transformers. I'll have to order one.
Old 09-25-2011, 09:19 PM
leadlike's Avatar
Here are the notes on replacing the interstage transformer. On a radio similar to yours, I used modification C:
http://www.philcoradio.com/tech/audio.htm
It kind of reminds me-while most radios of this period are set up like yours, with the last two stages transformer coupled, I have an American Bosch radio from the same period that is entirely resistance coupled. Maybe Wa2ise can explain the advantages/disadavantages of these circuits.
Old 09-26-2011, 09:24 PM
stusnyder's Avatar
It sings again!
Tonight I checked the transformers again. One was open both primary and secondary. The other one just the primary was open. Went to that posted link and bypassed the transformers and tied in the resistors and capacitor.
Fired it up and got stations!
Next step is to gut the transformers and mount these components in them.
