Old 11-25-2011, 03:19 PM
Zenith "Graemere" porthole scored
I picked up this Zenith G2346R 12" porthole set a couple days ago just across the Wisconsin border.
The cabinet appears to has identical styling to my 16" Monroe set, but it's 20% or so smaller.
I plan to restore both, but one will have to go after that.
Missing a few small knobs.
I pulled a few tubes and found numbers like 19BG6 and 25AX4 so I figure it must be a series wired set, but what's that huge transformer for then ?
I dug up a schematic and found that it is indeed a series filament hot chassis set, but the B+ and 5U4 are power by that big transformer.
The label inside indicates this model came with either a metal cone 12UP4A or an all glass 12LP4A. This has the 12LP4A and it appears to be original.
It has a wacky ion trap magnet composed of two magnet rings mounted on a brass sleeve.
The flyback looks to be in decent condition. The seller claims he powered the set up and got a raster with about two inches of vertical height.
I tried testing the CRT but had trouble with intermittent contacts in the loose base. The readings I did managed to get were deep in the bad zone though
I'll unwrap the electrical tape holding it on and try to fix it up.
I'm inclined to keep this smaller porthole set, but the 16" is more impressive and does not have a hot chassis
The seller also had an Admiral 16R12 for $10 with the original metal back and intact pencil box door so how could I refuse
I did a little research and found out the the brown bakelite set is the 16R12 and the black version is the 16R11.
Old 11-25-2011, 04:26 PM
TerrySmith's Avatar
TerrySmith TerrySmith is offline
Nice find Bob! I wish I could find a Porthole to restore, I guess nobody in east Tennessee bought a TV until the 1970's.
Did all that fit in the GTI?
Old 11-25-2011, 05:03 PM
Komet's Avatar
Komet Komet is offline
Nice find!!!
Old 11-25-2011, 05:15 PM
Yes, it sure did Even with the Zenith chassis pulled out of the cabinet. The seller sure was dubious when I pulled up though.
Originally Posted by Komet View Post
Nice find!!!
Thanks!
Old 11-25-2011, 05:20 PM
cwmoser's Avatar
cwmoser cwmoser is offline
Nice looking TV. Bet it will be really nice when you get finished restoring it.
CW
Old 11-25-2011, 05:48 PM
My RCA721TCS also has a sleeve shaped ion trap magnet, first of that type that I had seen.
Phil Nelson
Phil's Old Radios
Old 11-25-2011, 06:50 PM
Very cute little Zenith console, I think I'd keep the smaller one too.
I'm starting to think all the Admirals are secretly trying to organize at your place. If you ever run across an empty cabinet for a lonely 20Z1 chassis, don't be afraid to grab it for me.
Old 11-25-2011, 07:21 PM
Thanks! The cabinet is in even better shape than the one I picked up a few months back. I think a Howard's restore-a-finish rubdown and a few clear lacquer dabs here and there are all it needs.
Phil Nelson
Phil's Old Radios
Interesting - thanks for the info.
Could be. The seller put three sets on eBay at $9.99 and local pickup.
One was a huge Philco console with a busted 16LP4. No one bid on it.
I was the only bidder on the Admiral.
Just one other bidder on the Zenith, and I got it for $26. I hope it wasn't one of you guys.
At least two of the Admirals at my place are going away soon. They weren't mine to begin with - just dropped off for restoration.
Old 11-25-2011, 07:27 PM
I did some more digging into the Admiral.
The brightener can't be a good sign
I was surprised to find a Philco 17YP4 installed. That's a cylindrical CRT and I'm sure not original.
I found some really ugly repairs underneath. it does have the IF shield though. It's missing from the 16R11 I'm currently working on.
A couple dogbone resistors fell out when I touched them!
The candohm resistor in the upper-right had failed at some point in the sets life.
I tried to test the CRT and discovered it had a heater-cathode short. So perhaps it has good emissions and the brightener is just there for isolation
Old 11-25-2011, 09:18 PM
Penthode's Avatar
Penthode Penthode is offline
The sets are a good score: congratulations.
If the filaments are series string but uses a 5U4 for the B+, I wonder if the set would have a "hot" chassis? The hot chassis results in taking the B+ from the power mains directly and the power transformer would provide isolation. I am now curious to look at the diagram.
I suppose eliminating the filament power, there was the consideration of saving a bit of weight and cost with a smaller power transformer?
Old 11-25-2011, 09:32 PM
Thanks. There is a dedicated filament winding for the 5U4 for the B++ rectifier. The 25Z6 B+ rectifier is series strung.
According to this label on the back, left side of the chassis and the service info, the "top" of the chassis is hot.
Looks like there's an insulating layer between the top and body of the chassis. Weird setup.
No UL sticker but at least it's a polarized power cord.
Old 11-25-2011, 09:39 PM
Ah... so it was those sets. I actually watched those 3 auctions but I never bid. In fact I don't think I've ever bought a TV on ebay. I had no idea the Zenith set was so small, probably because I'm not familiar with the model numbers. Same problem I have with all those Admiral variations. That was sure a good deal, and I'm glad you saved them.
Old 11-25-2011, 09:48 PM
From what I understand, ET had no stations til LATE 1953/early 1954, after the "Freeze" was lifted... So the "Interesting" sets were gone by the time we got TV, unless you run acrost someone who bought one & tried to get WBT in Charlotte or WSB/WAGA in Atlanta...
Old 11-25-2011, 10:14 PM
M3-SRT8's Avatar
M3-SRT8 M3-SRT8 is offline
Oh, Bob...not another Admiral...?
Here's my Zenith 12" G2350RZ "Adams."
Old 11-25-2011, 10:54 PM
Hey, I only have 19 Admiral sets in my place right now - and two aren't even mine
That porthole sure is a beaut'. Love the Stooge porthole in a porthole effect too
