Old 12-17-2011, 07:32 AM
Daave Daave is offline
Originally Posted by Phil Nelson View Post
Unless you're extremely concerned about preserving original appearance, it's not necessary to unsolder the lugs and pull the can off intact.
If you cut it off and pull out the innards, it can be glued back on with JB Weld or a similar epoxy. Some people even use aluminum tape. It depends on how fussy you are about the appearance.
The following article has a section called Replacing Electrolytic Capacitors. It includes links to other articles that show a variety of restuffing methods, with photos and descriptions:
http://antiqueradio.org/recap.htm
Phil Nelson
Phil's Old Radios
Thats a very informative article thanks!
Old 12-17-2011, 12:36 PM
Originally Posted by Daave View Post
Now what does a dried up electrolytic look like?
Here's an extreme case:
Appearance is not a reliable guide. The failure rate for old electrolytics -- even those that seem OK at first -- is very high, and the cost of new ones is low. They fail in much newer equipment, too. I recently repaired a 1984 TV that I had bought new. Three or four electrolytics had bulging tops and one had burned off its plastic insulation. My ESR tester found several more bad ones. If the electrolytics in 1980s TVs are failing, small wonder that 1950s electrolytics have turned to garbage.
Phil Nelson
Old 12-17-2011, 03:37 PM
Buzzsaaw's Avatar
Buzzsaaw Buzzsaaw is offline
smellyyyyy!
Just make sure you do this outside.. Man.. it stinks! I usually put them in an empty Peanut butter bottle to keep the smell out of the house and I suppose a Zip lock bag would work.
Make sure your soldering iron is properly "tinned" good to conduct heat to the twist lugs through the solder wick.
Just a couple tips for what it's worth.
Good luck and Merry Christmas!
What is that smell anyway.. WhooooF! A-rack-a-rich!
Buzz
______________________
Buzzsaaw
Sunlitedreams.com
Old 12-17-2011, 04:41 PM
kvflyer kvflyer is offline
Yes, they do stink! But the only females that live here are feline. And they don't complain.
Old 12-17-2011, 05:42 PM
I did it in a garage, in my part of the world its -3 outside this time of year hah
Old 12-17-2011, 06:25 PM
Reece's Avatar
Reece Reece is offline
The last one I did smelled just like a cow barn when I pulled its guts out.
Reece
Old 12-17-2011, 09:40 PM
Originally Posted by DaveWM View Post
http://www.google.com/products/dremel+multi-max
this is it, mine was not cordless.
Dave-
How loud is that device? I have one of the Harbor Freight ones that you can buy for $20 with a coupon often, and it is extremely loud, bad enough that I will not use it without a pair of protective earmuffs on. I never tried mine for capacitor beheading, though.
Old 12-18-2011, 07:31 AM
geez no its not loud at all.
Old 12-20-2011, 01:04 AM
Thanks, now I know one of the differences with a brand-X version.
