Go Back   Videokarma.org TV - Video - Vintage Television & Radio Forums > The Amateur Radio Spot
Old 12-20-2011, 10:11 AM
Kamakiri's Avatar
Kamakiri Kamakiri is offline
Building a 2 meter 1/4 wave ground plane....
Picked up a 2 meter rig cheap on eBay, figuring that it's high time to get back on the amateur airwaves .
I was looking for instructions online on how to build a 2 meter dipole, and came across this:
I tried building some 2 meter dipoles and a coaxial dipole about 20 years ago, and never had much luck in getting them to tune properly. A much easier antenna to build is a 1/4 wave ground plane. All you need to build one is 5 pieces of stiff wire- each about 20-21" long (old wire coat hangers work great) and an SO-239 socket. Much simpler, doesn't need a balun.
Take 4 of the wire pieces and use needle nose pliers to bend 1 end on each wire into a small loop. Use a small machine screw through the loop to attach each one of the 4 wires to the chassis mount holes in the SO-239. Bend the wires so they point down about 30 degrees. Take the 5th wire, solder it to the center pin of the SO-239. Connect PL-259 connector on coax the the SO-239. That's it! Trim the vertical element for minimum SWR, final length should be close to 19". Should also work on 440 as a 3/4 wave antenna, although the radiation angle will be kind of high.
You can stand it up on the floor in the attic on the ground plane, using the 4 radials as "legs". Or use some electrical tape and fishing line and and hang it from the rafters by the vertical element. When I lived in a duplex, I has one sitting in the attic for years and never had a problem with it.
Decided to give it a whirl. I'll let everyone know how I make out. Going to pick up an SO-239 today and finish it up.
Question though, am I going to need to strip the thin clear plastic coating off the hangers, other than at the contact points?
And, does anyone have instructions for a simple 2 meter dipole? With the way I want to set the radio up, it'd make a lot more sense......
Old 12-21-2011, 12:59 AM
No, you will not need to remove the coating except where you will do the soldering.
I have never tried to make a 2m dipole, since dipoles are more typically used for horizontallly-polarized signals and 2-meter FM is vertical (therefore, the ground plane is a better choice). You could make a simple one with two ~19" pieces of wire connected to the center and outer conductors of some coax, but I have no idea what kind of signal you will get. 73
Old 12-21-2011, 05:57 AM
Kamakiri's Avatar
Got it done last night. Not half bad! Achieved an SWR of 1.6....not perfect, but I won't fry my finals. Got full quieting into the local repeaters, and even with it hung on the basement ceiling I was able to talk on simplex about 10 miles away easily.
Hung it in the attic crawlspace, and ran RG-8 down to the basement. Caught the end of the Western District Net, the local relay for the ARRL National Traffic System. I used to run several of the nets about 20 years ago. Glad to see that it's still around.
I'm back on the ham bands!
Old 12-21-2011, 10:11 AM
DC's Avatar
DC DC is offline
I've used similar antennas for years - simple and effective. The 21" recommended in the instructions seems a bit long. If the SWR is better at the low end of the band (144 MHz), trim and inch or so off of everything and I bet it will fall right in place. That antenna should have an almost flat SWR across the whole band.
73,
Don/K8BB
Old 12-21-2011, 01:56 PM
Kamakiri's Avatar
That's what I was thinking. I knew that it was a bit too tall, but where the antenna is at the moment in the crawlspace, will have to get moved anyways when the Christmas tree is put away.
That aside, I plan to have one of my local friends who's a ham help me do the fine tuning. It was enough "fun" having my fiance help me run RG-8 through the wall last night
