Old 01-02-2012, 07:32 PM
looking for sams folder info
hey all, someone posted for me what chassis a thordarson fly399 belongs to and it was said to be a motorola chassis 914, 918a. im trying to find out if the sams covers 914 thru 918a or just the 2 of them. i have a new old stock motorola flyback that i want to find the sams folder for the chassis to compare connections and see if it is electricly compatable to the set i have. does anyone have this info they could pass along maybe just the folder number and ill hunt for it. thanks
Old 01-02-2012, 09:11 PM
I was the one that quoted that. There is a world of difference between the small chassis Motorola sets, IE TS914, 918 and varients of same. The ETS908 uses shunt regulation and separately derived focus ETC. The small chassis in question uses focus from the second anode source and some kind of pulse or feedback HV regulation.
Old 01-03-2012, 05:16 AM
how much smaller could these chassis be because this flyback is big like the one in my 908. so you dont think there is any possible way this can be used at all. this fly is harder to find then some aftermarket flys because the one for the 908 was motorola only so this is why if some changes can be made to make it work i would like to try. well how ever the hv is regulated if it can be done it would be great since i have low hv now as it is, still not 100% sure the fly is the problem. i was told its the fly and i did certain things that should raise the hv to rule the fly out but nothing worked, stayed low no matter what.
Old 01-03-2012, 08:24 AM
Timmy: I have to look at both Sams folders again. Motorola flybacks were built in sections so each coil could be replaced. Maybe the HV coil could be swapped. The terminology, small vs large doesn't relate to the physical size, but the tube count, circuitry ETC. I even use that term for RCA chassis CTC24 VS CTC25.
Old 01-03-2012, 10:19 AM
this flyback is not burning or any smell but gets really hot so i still dont know if it may be a single turn short or what may be keeping the hv low, if a single turn short would do any of this. i am no where as good as all you guys here, but i try,lol.. im sure if it were the donut it would have been cooked by now. thanks.
Old 01-04-2012, 12:52 AM
You should look for a flyback and yoke ring checker like the EICO 944 or the B&K 1076 analyst. I gave away my spare to a friend a while back so I can't sell you one, but I seem to recall someone on ARF was trying to sell one some time back. You should really test the flyback AND the yoke to see which if either is bad. Once you know which if either your trouble is in it will help you attack and nail the actual issue instead of working solely in theory (which can make one start jumping at shadows after while).
Old 01-06-2012, 06:21 AM
if you have the schematics for the 914-918a are these chassis 23inch also like the 908? and does those 2 chassis use a hv tripler? im working with don lindsly on if i could use the fly for the smaller chassis for the 908 but hes looking to see the schematics as well. thanks timmy
Old 01-06-2012, 09:28 AM
IIRC, the TS914 were all 23EGP equipped. The 918's were built using 21,23& 25 CRT's. They all used 3AT2 HV rect tubes. The ETS908 were a good earlier design. The TS914,918 and 921 was the cost-cutting later design. The smaller chassis used a focus voltage dropping resistor from the second anode source.
Old 01-06-2012, 11:01 AM
so in your opinion could the fly399 be electricly used in place of the fly for the 908 with minor mods from what you see on your schematics because i still cannot find the schematics for those chassis to try to compare. don lindsly wants to see it as well but i cant locate them. could you tell me what the folder number is?
Old 01-28-2012, 04:12 AM
sharejutt sharejutt is offline
Banned
C000021a
STOP: C000021a {fatal system error} DELL?
