Old 02-08-2012, 11:09 AM
mstaton's Avatar
mstaton mstaton is offline
"Book em Dano!"
CTC-16 64-65. I have 2 CTC-16's form '65. I know they had them in '64. Doug's '64 CTC-16: http://www.youtube.com/user/drh4683#.../0/V2uHthZPsVU
Old 02-09-2012, 11:33 AM
well i got the set but i want to check the crt which is an rca and it says on the cabinet that it came with a 21fbp22 but the one in it says on the crt sticker h-19vabp22 rare earth hy lite, so would this be tested the same as a 21 fbp22. i guess it was replaced at one time. well i edited this i checked the crt as a 21fbp22 and there is good emissions readings but the life test the needle drops a little fast on each gun. the scale says anything over 200 is good so the red was 325,green 500, blue 500 . it has hv but no pic or snow so the tubes have to be checked so now i have to tear it all apart for caps since it has a nasty 60hz hum and the am-fm is soild state so its got to be around 1965.
Old 02-09-2012, 12:03 PM
ctc17 ctc17 is offline
All 22 series tubes use the same tester setup?
Did you clear the shorts and condem the HV yet?
Old 02-09-2012, 12:09 PM
yes cleared the shorts and thats when i got the good readings. and no i did not condem the hv since i have to get another probe. 22 series?
Old 02-09-2012, 12:12 PM
xxxxx22
Old 02-09-2012, 12:14 PM
i dont get it...............
Old 02-09-2012, 02:15 PM
21fjp22
21fbp22
21fuq22
25ap22
25gp22
25vap22
22jp22
22fuc22
19ep22
on and on and on
Old 02-09-2012, 11:25 PM
mstaton's Avatar
"Book em Dano!"
They are trying to say that the "22" series CRT's will use the same testing protocols. Yes you can test it as a 21***22. Leave it on the tester all night at 6.3V and see if it's better in the morning. They usually always do better when they are awakened from a 30 year slumber. DO NOT REJUVENATE! All solid state tuner/amp means it's a '64 or '65. Probably a 16 clone. 60 cycle hum=new electrolytics. It wont do much until that's corrected. Any pics? Does the stereo/amp work?
Old 02-10-2012, 07:59 AM
the ac hum was so bad that i got a little noise from the tuner but i shut it down because of the caps. did a quick check of tubes and no wonder i got nothing on the crt because the video output tube was so bad it lit up all different colors with shorts. and no didnt do any rejuv. the whole set is in pieces now. i dont have a schematic for this chassis but would you know what the cathode current should be and what pin on the 6je6 for cathode current,#3 or #5.
Old 02-10-2012, 11:03 AM
mstaton's Avatar
"Book em Dano!"
Pin 3 is what you want. Pin 5 is the heater ground.
Old 02-10-2012, 03:02 PM
any idea what the cathode current should be?
Old 02-10-2012, 03:56 PM
190-220ma
Whats the model/chassis number?
Old 02-10-2012, 04:16 PM
thanks CTC17
Old 02-13-2012, 01:28 PM
on these magnavox stereo solid state, the cap right of the 2 diodes b+ right off the power transformer 30 volt 1000uf gets hot then vents. checked the output transistors for shorts and none and tried another cap, no good. the cap used to come from a can cap but im useing single caps which i used 50v 1000uf instead of the 30v.
Old 02-13-2012, 01:38 PM
mstaton's Avatar
"Book em Dano!"
Do you have the cap reversed? Observe polarity with electrolytics. Double check or they will just keep venting.
