Old 02-12-2012, 12:43 PM
Rca t-120
guy gave me a few sets, this one was the best of the bunch. Has a good 12LP4 that had most the dag falling off. I picked up some slip plate brand spray paint, that worked great. It looks completely un touched. I started with a full recap of the tubular caps. EVERY one of them was bad, no big surprise as they were all papers and bumble bee, and black beauties. EVERY can cap section was shorted, so they got restuffed as well, had 3 on the top and 1 on the bottom, bunch of electros. I check a few of the resistors esp the ones that were on term strips shared by the tube caps getting replaced. I can't decide if I want try my 5" test crt or bother with reinstalling the 12LP4. prob go with the test crt just to see how it works.
oh will go thru all the tubes for shorts 1st I tested the sweep tubes, mostly 6sn7's and the HOT all tested fine. I just dont want a shorted tube ruining a resistor somewhere.
Old 02-12-2012, 06:54 PM
got it. At first the horz was way off, would lock on 3 images. It ended up just needing the horz transformer bottom slug needing to be adj A LOT which surprised me. I checked the sync sep pulse with a freq couner and it looked good (15750 or there abouts) but the drive signal to the HOT was 125750. I adj the bottom slug to note which direction would speed up the osc, several turns out did the trick so now it has a rock solid sync.
The voltage divider resistor then shorted out to the frame, I was able to stick a piece of cardboard in there to temp stop that, and the 850 section opened up as well (same section where the short was) so I will have to order up some power resistors to complete it. will need to figure out a neat method for insalling them, I like to keep all the parts in the same location (like stuffing can caps) but the power resistor will be a challenge.
Old 02-12-2012, 07:45 PM
Could you simply solder the new resistor across the old terminals? Maybe make sure the old stays open by cutting the element a little.
Old 02-12-2012, 11:20 PM
it seems to be shorting to the chassis, hard to tell. There were two unused points on a term strip nearby, I did the open section there the 215v to 135v 850ohm. I Made up a 850 from 4 5w sand resistors i had on hand. a 300+350+100+100 in series. I work out to about 3watts 3.5 watts 1 watt and 1 watt. No wonder that resistor is out back its nearly 9 watts total (and the spec says a 7 watt). There are still two more a 650 and 650 they seem ok for now but I will fix that next time I go to the surplus store. I pretty much used up my supply of sand resistors. I do like the 5 watt jobs in series, maybe a 300+350 for the 650's.
Its working great now, I have posted some pics over at ARF.
Old 02-13-2012, 01:48 PM
droptop's Avatar
droptop droptop is offline
Behind in Time
Where did you find this product? I have a 21CYP22 that most of the dag has fallen off.
Thanks,
Rick
Old 02-13-2012, 03:01 PM
google it there are plenty of places. slip plate lubricant.
Old 02-13-2012, 03:20 PM
Grainger part #1WVK7. (I have it memorized now... Hmm, it could be a good password for a Web site.)
Old 02-13-2012, 08:08 PM
tvtimeisfun tvtimeisfun is offline
Hey we need the photos to be loaded on VK so those of us who are not on AK can see them thanks,,,
Old 02-13-2012, 09:55 PM
dinked around some with it, added a cap and resistor in series with the CRT cathode and brightness control, this pretty much eliminated all the retrace lines that were a problem in low contrast scenes.
Old 02-13-2012, 10:04 PM
wow after have it on for hours the PT is barely warm, nice change from some of the color sets I work on.
Old 02-14-2012, 12:58 PM
So whats the best paint to use to match the old bakelite brown (its painted that already)?
Old 02-14-2012, 10:50 PM
ok its metal not bakelite so I can handle that.
need a source of dry transfer lables for controls, any good suppliers?
