Old 03-31-2012, 10:17 PM
fox_rivers's Avatar
fox_rivers fox_rivers is offline
Here's an interesting set
I've never seen a projection addon like this. http://www.ebay.com/itm/Ca-1948-RCA-...f#ht_555wt_932
Mastered soldering with paws.
Old 03-31-2012, 10:35 PM
charokeeroad's Avatar
charokeeroad charokeeroad is offline
John Q
Humm. Does the picture project onto the wall, ceiling, floor?.. With all the write up the seller doesn't say where in CA he is. CA is a big place.
Oh I see, it's in Portland. Maybe Ca isn't CA it must mean circa.
A quick qooqle search came up with this. http://www.myvintagetv.com/norelco_pa2.htm It projects onto a screen or white wall.
Old 04-01-2012, 12:52 AM
I have this same unit, not near as nice but it was cheaper, didn't come with an 8-TS-30 though.
It projects on whatever you want it to I suppose, a proper screen would probably be preferred but a wall should work.
The 8-TS-30 may have a negative picture for a reason, the Duo-View requires a TV set with a certain polarity Video drive to function, someone may have reversed it to
work with it. Just a guess.
I've never attempted to power mine up since it requires a modified TV and some cables to go along with it.
Old 04-01-2012, 05:35 AM
John Q
Hi Eric, If I'm understanding so far, the set has been modified physically to work with the projector. I'll assume for the moment that the 8-TS-30 meets all the other requirements. Does that mean that it can't work without the projector? What are the chances that the projector can be restored? Are the parts out there to fix it? If the tv set has been midified and can't work without the projector wouldn't that devalue the otherwise valuable set? What do you think the overall value of the combined units is?
what do you think each piece is worth?
Old 04-01-2012, 09:12 AM
John Folsom's Avatar
I have a Duo-View projector hooked up to a 8TS30, and both operate properly, and no alterations to the TV were required, other than hooking up wires to obtain video and sweep signals for the projector. The projector has video amplifier and vertical and horizontal and HV circuits to drive the Norelco portelgram projection unit. It has been a very long time since I put them together, so the details of the electrical interconnections are a bit fuzzy. The projector will make a 3'X4' picture in a dark room. A standard home movie/slide screen works well.
John Folsom
Old 04-01-2012, 09:54 AM
John Q
HI John
Are there any other electronics components besides the projection tube in Duo-View projector ?
http://www.tvhistory.tv/1949_3NP4_2....elgram_CRT.JPG
Old 04-01-2012, 11:16 AM
Yes, there is a chassis which contain video amp and deflection circuitry, and a regulated HV power supply along with the projection CRT (3NP4), yoke, and projection optics and housing. Schematics for the duo-vue electronics and optics are available. Don't recall if it was in Sams or Riders or elsewhere. The 3NP4 CRTs are quite rugged and reliable.
John Folsom
Old 04-01-2012, 12:53 PM
Einar72's Avatar
Einar72 Einar72 is offline
Chasin roundies since '79
Looks like the two units need to be un-married before tossing on the roof of my Fiero. Problem is it's rainiy and cold all the time here...
Old 04-01-2012, 12:56 PM
fox_rivers's Avatar
That would be an entertaining sight to see! If your gonna go to that extreme you might as well tarp it too.
Please post pics next time you do something like that.
Old 04-01-2012, 01:12 PM
Einar72's Avatar
I actually put stuff on the rear compartment - as long as it doesn't block the engine bay air outlets, then strap it down using ratcheting ties hooked in the wheel-well openings. Works well with console radios!
Old 04-01-2012, 02:36 PM
John Q
You couldn't go wrong with that deal even at full price and a rental truck.
Old 04-01-2012, 04:50 PM
As noted the mods to the TV used aren't permanent, wires cut and spliced to go to the Projection unit.
I paid $50 for my Duo-View, it's in decent looking shape inside but the cabinet needs refinished and a new side cover made.
I have no idea what condition the tube or electronics are in, I assume the normal recap is in order.
It makes a nice roll around TV stand if nothing else.
I would think the 8-TS-30 is worth close to the opening price of this Auction.
Old 04-01-2012, 09:57 PM
Penthode's Avatar
Penthode Penthode is offline
Perhaps the negative picture is simply the contrast control turned too high? I believe the 8TS30 does not have AGC.
Old 04-01-2012, 10:20 PM
earlyfilm's Avatar
Eternal Member
I've been drooling over that set all day, but 2,845 miles (4578 km.) each way is a bit much to drive.
The manual for the projection attachment can be found at:
http://www.earlytelevision.org/images/duo-view.pdf
and the RCA 8TS30 at:
http://www.earlytelevision.org/image...-rider-tv2.pdf
More information on this projection system can be found at:
http://www.earlytelevision.org/norelco_protelgram.html
James
Old 04-01-2012, 11:45 PM
Einar72's Avatar
I do have a full-sized sedan as well. I'm more interested in the 8TS30, all you back east get one or two chances a week at one, ones out West are usually in Kaa-li-fornia; this is unusual seeing one in the Pacific Northwest! Actually, the Nor-el-co could be used to fix my 8PCS41 that my ex tossed its 5TP4 (and a 5AZP4 went as well). The burner-bib-shaped mirror that badly needs re-silvering and all the barrel apparatus could be shelved as well.
I couldn't find the Norelco "Floating Heads" commercial from 1961, but someone used a familiar TV in this later Nor-el-co mash-up:
http://www.youtube.com/watch?v=-YoKb...eature=related
