Old 04-30-2012, 09:55 AM
Prolly worth a shot...What have you got to lose ? If it saves a truly Unobtainuim CRT, then, it'll be worth the effort.
Old 04-30-2012, 10:12 AM
miniman82's Avatar
First Light: 1952-2011
The problem you will have is that the silicone doesn't adhere nearly well enough to prevent a vacuum leak, the air would just creep under the sillycone and still get in. That's why I think the nickel plating that Bob has done will work, because it's actually a hard coating on the metal ring, as frit is to the glass bell.
Evolution...
Old 04-30-2012, 09:54 PM
M3-SRT8's Avatar
M3-SRT8 M3-SRT8 is offline
I dunno....silicone bonds to both glass and metal very well. If you prep the surface with some lacquer thinner or alcohol it should bond well.
Also, silicone flexes very well, and stands up to high temperatures.
Old 04-30-2012, 10:04 PM
miniman82's Avatar
If such an easy solution worked, don't you think it would have been tried already?
Evolution...
Old 04-30-2012, 10:31 PM
Einar72's Avatar
Einar72 Einar72 is offline
Chasin roundies since '79
If I had a dog in this fight, I'd try this stuff:
http://www.pchemlabs.com/product.asp?pid=2629
Old 05-03-2012, 06:33 AM
M3-SRT8's Avatar
Yeah, I know about that stuff. Do you think a CRT gets THAT hot? Regular silicone is pretty good at standing up to temperature, I believe...
Old 05-03-2012, 06:36 AM
M3-SRT8's Avatar
Has anybody tried it?
Old 05-03-2012, 08:20 AM
Reece's Avatar
Reece Reece is offline
The ones to ask would be those involved with the early television museum project of trying to seal leaking CRTs. I don't think they would have gone to all the trouble with frit glass and such if an easier method would work.
Reece
Old 05-03-2012, 09:59 PM
miniman82's Avatar
It won't even keep the oil inside my VW engine, there's no way it's gonna keep air out of a CRT! lol
Evolution...
Old 05-11-2012, 06:51 PM
John Folsom's Avatar
After a glorious time at the ETF convention, its back home and back to work on the Crosley.
First up is the sweep/power supply chassis. A straightforward recap job. Three of the four electrolytic cans were restuffed. The fourth, a single section 500uF/50V was replaced with an axial electrolytic under the chassis, leaving the old can unconnected but in place for cosmetics.
Now on to the main TV chassis......
John Folsom
Old 05-11-2012, 08:13 PM
tubetwister tubetwister is offline
Banned
I thought the Dumont Sovereign was the only 30" set back then just goes to show what I don't know.
Old 05-11-2012, 08:53 PM
I am guessing that the DuMont 30" set was the only one produced in any quantity. Dumont made two production versions of the 30" set.
As I have not been able to find any documentation published on the Crosley, and the Sweep/Power Supply chassis is put together with nuts and bolts (no rivets), I think the Crosley was produced in very small quantities.
John Folsom
Old 05-11-2012, 09:00 PM
holmesuser01's Avatar
I'd love to have a set with no rivets.
Old 05-11-2012, 10:10 PM
snelson903 snelson903 is offline
that is i think the first one i have ever seen ,sure is interesting set.
Old 05-17-2012, 03:33 PM
The recap of the main TV chassis is complete. The electrolytic cans have been restuffed. All the silver micas were replaced to improve reliability. A goodly number of off value resistors were replaced.
All of the AC wiring needs to be replaced, and tubes still have to be tested. And the little UHF converter chassis needs to be recapped. And when all that is done, I still have to swap out the CRT. So still some work to do.....
John Folsom
