Old 07-20-2012, 08:35 AM
take a look at the 2 other pics i just put up.
Old 07-20-2012, 08:43 AM
has anyone heard from don lindsly from out west where the bad wild fires were. i had talked to him awhile ago and all was good being he was 60 miles from the fires but it had since spread.
Old 07-20-2012, 08:59 AM
ctc17 ctc17 is offline
I recommend you change C731, C732 and C726 while you have the chassis. I have seen those short on several sets and they ALWAYS test bad. Use red drops not yellow Chinese trash.
These couple the grids of the. 6GU7s and are located between power resistors and the tube. They get baked to death
Old 07-20-2012, 09:11 AM
ok i wrote that down as having to be done
Old 07-20-2012, 09:19 AM
would those .01 caps be 400v or 600v.
Old 07-20-2012, 09:39 AM
Either will work.
Also check all the solders in the are of the 6GU7s, gently rock the blueish power resistors in that area while looking for movement of the leads on the bottom of the board.
Old 07-20-2012, 09:54 AM
oh yes ive come across that befor with all these sets with bad solder joints. which it has now because wires were soldered from one tube to another and im sure there are many more. so what i do is ill go over everything but it takes awhile but i wont have to do it again or be surprised later. just like the maggie i have maybe at one point someone in there had bumped into the i think it may have been the sound take off coil and thought it was a bad joint but turned out to be that when it was hit it moved it so far the wire on the coil is thinner then hair and broke off and i used a magnafying glass to see it to repair.
Old 07-20-2012, 01:43 PM
Looking at the picture in entry # 29, the CRT label. I see RCA service purchased their CRT's from Channel Master.
I think by then, they were kind of "estranged" from the parent company.
I remember RCA service would milk every hour out of the CRT, before begrugingly replacing it. That is when the set was under contract.
Sears and others did the same thing.
Old 07-20-2012, 03:56 PM
how would you know its from channel master?
Old 07-20-2012, 07:15 PM
Originally Posted by mstaton View Post
nevermind
i had to use one of your posts to get you a message because it would not let me send a PM as your end is full and need to delete some. i just want to thank you and if i could return the favor somehow then give me a shout. thanks again timmy
Old 07-20-2012, 08:42 PM
marty59's Avatar
marty59 marty59 is offline
Not sure how high your line voltage is but there is another (unused) primary tap on the power transformer if B+ and filament voltages are too high.
Old 07-22-2012, 08:17 AM
does anyone know the specs on the 4 diodes on the sound board in the ctc16x chassis? they call them sr201 up to sr204.
Old 07-22-2012, 09:00 AM
1 amp 600 volts.
Old 07-22-2012, 09:30 AM
would that be the same for all 4 diodes?
Old 07-22-2012, 11:07 AM
Yes.
Most people use 1N4007s
You could use1N4005-4007
www.diodes.com/datasheets/ds28002.pdf
