Old 07-22-2012, 10:12 PM
Originally Posted by ctc17 View Post
You can measure the capacitance with an eye type cap tester. There should be a spec for that crt.
I don't think it would be all that critical would it?
Old 07-22-2012, 10:33 PM
It doesn't seem so since the datasheet says 850-1400pF. I'm measuring around 900pF with my vintage Solar CB-1-60 cap tester.
I would think it's also possible to stick a 1000pF HV cap on the flyback to filter the HV and not use the coating at all.
Old 07-22-2012, 10:34 PM
ctc17 ctc17 is offline
well the dag + glass = filter capacitor. IIRC the small crts are something like 800-1200pf, its enough to smooth out the hv.
Old 08-05-2012, 02:40 PM
I sprayed a little more slip plate in the corners and got it up to 1,000pF.
Then I did some final tweaking and put the set back together.
I sprayed some semi-gloss black on the metal portion of the cabinet and silver paint on the trim. I'd still love to find a better cabinet someday but at least it's somewhat presentable now.
Old 08-05-2012, 02:46 PM
holmesuser01's Avatar
First, I see the resolution of the video. Yes!
This little set has probably never seen such a clean signal... Are you going thru the tuner?
Old 08-05-2012, 02:49 PM
Boobtubeman's Avatar
<---WANTED: Motorola 17P6
Holy smokes thats Sweeeeeeeeet!!! Exelently done!!!
Old 08-05-2012, 02:51 PM
Thanks!
Sure. I'm using an over the air ATSC to NTSC converter box. The RF output on channel 3 is going through a 75-300 balun into the antenna terminals on the back of the set.
Old 08-05-2012, 02:54 PM
Thanks!
Sho' looks purdy.
Loving the way this set has come back to life. Excellent work, as usual.
So what is the test pattern showing the video response at?
Old 08-05-2012, 02:59 PM
I think around 3.5 MHZ. I'd have to dig out the Sencore VA62 manual to know for sure. Also, I haven't done an alignment on this set yet.
Old 08-05-2012, 03:14 PM
snelson903 snelson903 is offline
that's a nice sharp picture ,good work .
Old 08-05-2012, 09:48 PM
Looks great!
Old 08-05-2012, 09:56 PM
WOW! That thing really came back to life! It looks a lot better all cleaned up. I hope you can find a bezel for it. That picture looks perfect!
Old 08-05-2012, 10:48 PM
Boy, great picture on that one.
Phil Nelson
Old 08-05-2012, 11:31 PM
Thanks. I'll wait a while and if a bezel doesn't turn up I'll break out some Bondo and try to repair this one.
