Old 08-08-2012, 08:49 AM
DavGoodlin's Avatar
Motorola Minion
Jeff,
I have a 3.2 ohm speaker from a 70's era Zenith TV, I think its 4" are you interested?
Old 08-08-2012, 12:50 PM
Originally Posted by DavGoodlin View Post
Jeff,
Yes, thanks, I would be. I'll send you a PM with my name and address.
Old 08-08-2012, 12:58 PM
PM sent.
Old 08-08-2012, 07:03 PM
ctc17 ctc17 is offline
I have been working on some Zenith sets form that era and most of the problems have been open resistors.
They seem to be worse than the caps in these years.
After you recap, start by checking your DC voltages just to make sure you dont have a plate resistor thats way off or open.
This radio should do very well.
Ohm out the antenna to make sure its not open somewhere in the coil.
After all thats done check the alignment. Its best to use a signal generator but you can tweak on it a tad and get a feeling if its way off. Mark the screws before turning them.
Most of the radios I see the alignment is right on, the ones that are off are always off so far they hardly work.
You can use an ohm meter to check the tuning cap. Check each section and see if it shorts below 800khz. I have had some of those just slightly bent that are hell to get straightened out
Just some notes form the 20+ of these I have fixed in the past few months.
Old 08-09-2012, 12:02 AM
I'm sure the antenna is OK since I do get a good number of stations. I also found out that there were at least two bent plates on the tuning capacitor rotor, so I carefully rebent them and got the lower end of the BC band again. The bent plates must have been acting as a dead short across the antenna or oscillator coil right around 800 kHz, but did not affect reception above that point.
I don't have the proper alignment tool for the IF transformers. The IFs in the H511 series require what Zenith calls a "68-19" alignment wrench, which allows adjustments of the top and bottom coil slugs independently of each other. The wrench is almost certainly no longer available (NLA), since these radios were made over 60 years ago.
While studying the schematic (I downloaded a copy from Nostalgia Air), I noticed at one corner of the document, to my surprise, a note stating that the 3-section electrolytic filter capacitor in the H511 Zenith radios is a special non-inductive type that cannot be directly replaced by a standard electrolytic -- if this is attempted, several additional components must be added to the power supply. I am wondering what is or was so special about these radios that they even needed a non-inductive B+ power supply filter capacitor in the first place. I realize the H511 series was one of the best series of table radios Zenith made in the mid-1950s and, therefore, the sets used high-quality components, but I can't for the life of me see how the filter capacitor would make any difference as long as it does its job. Did the non-inductive Zenith filter caps do a better job than ordinary caps of filtering noise and hum from the output of the rectifier tube, or would there have been a risk of damaging said rectifier tube if a standard filter capacitor (without the additional components I mentioned) was used?
Thanks much.
Old 08-09-2012, 12:11 AM
The alignment tool is a GC 8284 .080" hex tool. They are $1.25 at my local spot. Nothing special there.
I doubt there is anything special about that cap. If you replace it with 3 caps it would be fine.
Old 08-09-2012, 04:04 PM
DavGoodlin's Avatar
Motorola Minion
I have the Sams 147-13 on that radio. The cap seems like a standard two-barrel, 60 and 20 with a 1,000 ohm in between.
The cap you need to replace first is a .01 mfd (C7@10000 pf on the sams) from 35W4 pin 6 (mid-tap on heater) to the on-off switch load side (B-).
That one blew up both the 35W4 and pilot light on my J615. I gots the tubes, but theres only so many in the world.
Old 08-09-2012, 08:05 PM
Originally Posted by Jeffhs View Post
... I realize the H511 series was one of the best series of table radios Zenith made in the mid-1950s and, therefore, the sets used high-quality components, but I can't for the life of me see how the filter capacitor would make any difference as long as it does its job. Did the non-inductive Zenith filter caps do a better job than ordinary caps of filtering noise and hum from the output of the rectifier tube, or would there have been a risk of damaging said rectifier tube if a standard filter capacitor (without the additional components I mentioned) was used?
Odds are that modern electrolytic caps would do fine. Zenith likely needed the cap to be low inductance to act as RF bypasses to ground. To keep RF and or IF signals from leaking back to adjacent stages, which may cause undesired oscillations.
Old 09-24-2012, 03:48 PM
TronCarter TronCarter is offline
I have looked high and low online and can't seem to find any place that actually has the GC 8284 in stock. Most of them are quoting a 8-10 week lead time, which usually means they have no idea when or if that tool will be in stock again. What is your local source?
Tron
Old 09-25-2012, 11:44 AM
Reece's Avatar
Reece Reece is offline
Radio Shack sells a kit with several plastic alignment tools in it, one of which will do those "high/low" IF's.
Reece
