Old 09-12-2012, 07:46 PM
You know about this, but do be careful that your kitty cat doesn't go noseing around the chassis when the TV is powered on. And cats like to rub their chins against various objects, hopefully not objects carrying high voltage...
Old 09-12-2012, 07:49 PM
AiboPet's Avatar
AiboPet AiboPet is offline
"micro" and quirky
Location: I'm in San Diego, but lived in Hong Kong for a long time
Service tech opens your set, sees a black cat....."Well THERE'S yer probbblemmm!!"
My current "holy grail" is trying to get enough parts together to get a Singer TV6U going. Been kicking my ass for nearly a year now :-P
Old 09-12-2012, 09:16 PM
rcaman's Avatar
rcaman rcaman is offline
i would never power a set up with my putty tat in there......
Old 09-12-2012, 09:18 PM
rcaman's Avatar
Originally Posted by sampson159 View Post
well,the bliss was short lived.i went to the kitchen for some coffee and when i returned.no high voltage.changed out tripler and that got it going again but no vertical deflection.module,transisters are all good.have to pull the chassis and run it down.didnt see anything blown or swelled up.hopefully it not a pin amp transformer or something i dont have.this set uses a ctc58 chassis.its a bare bone set just like the other one.my donor set is a 19 inch set that uses an inline crt.same tripler and vertical transistors.might need a sams on this if anyone has one available.never did see the rest of the game!
fixed one years ago for the same problem seems like a resistor opened it was on the circuit board with the mak and mal & video out boards. steve
Old 09-12-2012, 09:45 PM
rcaman's Avatar
i am almost sure i circled the bad resistor in the schematic. i will look tonight or tomorrow for that schematic. i believe it was a resistor off the video line. it ran me in circles which is not hard to do anyway. lol steve
Old 09-13-2012, 03:36 AM
rcaman's Avatar
didn,t find any notes on my schematic.
is your service switch contacts CLEAN
Old 09-13-2012, 03:48 AM
rcaman's Avatar
i did not finish before the post uploaded ??
anyway check r609 33k r620 820k on the circuit board with the service switch
magoo1 voltage pinouts
pin3 ground
pin 4 30.6v to sweep
pin 6 31.6 to sweep vertical output transistors
pin 7 8v to height control
pin 8 30.6v
pin 10 83v b+ in
pin 127.90v v sync
maybe this will get you started in the right direction
steve
Old 09-13-2012, 10:51 AM
sampson159's Avatar
sampson159
thanks for info.service contacts are clean,transistors are good.i checked them in another set.have to get moving on this.it is my daily watcher in the garage and i spend more time there than i should!i will keep you posted on progress.nib doesnt mean much after 38 years in storage!
Old 09-13-2012, 10:10 PM
Ron, I'm not sure that I have a Sams but I should have a factory manual for it. I'll mail it to you if needed.
Old 09-14-2012, 07:33 AM
sampson159's Avatar
sampson159
i ll take it, bryan.i was out at devry yesterday and they have every sams that has ever been printed,except the ones for early to mid 70s xl100s.looks like someone else had an issue with these sets.
Old 09-15-2012, 10:14 PM
Check the exact chassis number, there should be a suffix. The Sams index lists two different versions and I suspect the factory manuals break it down further.
Old 09-16-2012, 12:25 AM
ctc17 ctc17 is offline
The tripler failed so you changed it now you just have a vertical line? Thats an interesting one....
The output transistors may be good but one of the small ones on the module may have failed. I have seen that in the xl100s.
If you need a scan of the vertical circuit i can do it in the morning?:smok e::y es:
Old 09-16-2012, 08:31 PM
sampson159's Avatar
sampson159
i tried the module in my other set.its good.transistor are good also.i will try the yoke this week.set is a ctc 58 chassis.i can use that scan.thanks to all!
Old 09-18-2012, 07:51 PM
