Old 09-24-2012, 09:49 PM
AiboPet's Avatar
AiboPet AiboPet is offline
"micro" and quirky
Location: I'm in San Diego, but lived in Hong Kong for a long time
I hope you are still planning to variac this to life!
My current "holy grail" is trying to get enough parts together to get a Singer TV6U going. Been kicking my ass for nearly a year now :-P
Old 09-25-2012, 02:10 AM
I new this was a common point of failure and even bought some replacement sockets. Unfortunately, the break didn't reveal itself until after I wired the PCB back in
I globbed a little solder on the break and it's restored continuity through the PCB (for now). If I ever need to pull the PCB for some reason, I'll replace the socket.
I still don't have continuity through to the AC plug though.
There seems to be another break somewhere between the CRT and tuner tubes.
Old 09-25-2012, 03:00 AM
I fixed a loose tube in the tuner and finally have filament continuity Here it is powered up with the fusistor pulled out so there's no B+.
I'll try a full power up after I get some sleep.
Old 09-25-2012, 03:13 PM
Question Startup filament current
I checked the filament current when the set is turned on and found it peaked at about 1 amp then settled down to 600mA after 10 seconds. That's with a single CL-90 (120 ohms cold) in place of the original thermistor (400 ohms cold).
I then tried it with two CL-90s in series and got a peak or around 850mA before settling down to 580mA.
I checked in my RCA tube manual but couldn't find any data about permissible cold filament startup currents.
Does anyone know if it's OK to have 1A (or more) running through a 600mA tube for a few seconds every time a set is turned on ?
If not, I could go with three CL-90s in series to really keep that current surge down.
Old 09-25-2012, 03:56 PM
I did some searching on the web and discovered Ametherm has a nice line of thermistors including these with a cold resistance of 220 ohms.
1 Amp max, 2.2 ohm hot
http://www.digikey.com/product-detai...873490?cur=USD
2 Amp max, 0.9 ohm hot
http://www.digikey.com/product-detai...873476?cur=USD
Old 09-25-2012, 05:17 PM
I hooked up a test speaker, popped in a fusistor and slowly bright it up on a variac until I achieved full B+.
Only the tubes weren't lit up until I wiggled that tube in the broken socket again. I'm definitely going to have to replace it!
After fiddling a bit with the tuner, I heard our LPTV channel 6 coming through the speaker
I removed the screw locking down the CRT and popped it off the chassis.
I'll lay down some padding on my workbench so it doesn't get damaged and hook it up next.
Old 09-25-2012, 07:08 PM
I hooked up the CRT and powered it up again. That got me a nice bright horizontal line
I quickly turn the brightness down to avoid a burn. Wiggling the 10DE7 vertical osc. and output tube produced some vertical deflection so I'll start checking there.
Old 09-25-2012, 10:46 PM
Ugh, another broken socket pin.
I globbed some solder on that break too and achieved vertical deflection
After a bit of tweaking, I got a watchable picture.
The hor. linearity is off, vertical hold touchy, channel oscillator slugs are off and it needs an alignment, but it's progress
Old 09-25-2012, 10:51 PM
Boobtubeman's Avatar
<---WANTED: Motorola 17P6
After all that.... ALIVE is GOOOOOOD!!!! and a picture too??? BONUS ROUND!!
SR
Old 09-25-2012, 10:52 PM
josephdaniel's Avatar
josephdaniel josephdaniel is offline
Learning as I go
Wow! That looks great so far!
Old 09-25-2012, 11:41 PM
And what's the first thing we see? Mr Death!
Maybe you should have gone ahead and replaced all the sockets!
Old 09-26-2012, 12:00 AM
LOL - I hadn't noticed that when I snapped the pic.
I swear all these 9-pin sockets looked fine when I inspected them. I'll be pulling the PCB back out and replacing them. Better order up some more for my other sets too
Old 09-26-2012, 12:10 AM
mstaton's Avatar
mstaton mstaton is offline
"Book em Dano!"
That's funny, as I read this post, that episode of TZ is on right now.
Old 09-26-2012, 04:15 AM
snelson903 snelson903 is offline
its alive ! you sure took that tv a long way back to the living .
Old 09-26-2012, 07:00 AM
cwmoser's Avatar
cwmoser cwmoser is offline
Hey Bob, I'm collecting knowledge on these old Predicta's
because they seem to catch my eye. Can you post a
picture of a new tube socket and tell who can supply them?
If I find a Predicta, might as well replace all the tube sockets
with the recapping.
Thanks
Carl
CW
