Old 10-07-2012, 04:57 PM
tv beta guy
Guest
Posts: n/a
No go...
It was late last night and I didn't want to mess with it any further. So I just tried it again. I hooked a DVD player up to the TV and turned it on.
It squealed, and after about 7 seconds it blew the 4A line fuse again. So the original problem is still there that most likely took out the original HOT then.
EDIT: Actually, I just caught this now: There is a broken jumper from capacitor C3308 and a white wire just above ICX3301 (pulse width modulator). The SAMs I have is for a 9-160-04 module and does not show any jumper there. Any insight on this? I'll pull the chassis back out later to trace that white wire out and figure what is going on.
Old 10-07-2012, 06:30 PM
The 9-160 series of modules went through many changes & revisions during it's lifetime. That broken jumper and white wire may be normal. The squeal you hear may be caused by a short that's placing a heavy load on the horizontal output circuits; thus, blowing the HOT. Make sure you check all the diodes that are in the area close to the flyback and it might be possible that you have a bad flyback. If that's the case, you'd be better off to find another module. I've used flyback transformers salvaged from other modules; but, a new module would be the best way to go and I'm not so sure that Zenith ever offered that flyback as an individual replacement part.
Old 10-07-2012, 06:49 PM
tv beta guy
Guest
Posts: n/a
I did check all the diodes near the flyback and they check good. I have a bad feeling it is the flyback.
I already have an Ebay search setup for that 9-160-06 module. Hopefully a NOS or working one will show up. And I'll just keep that existing module for other parts.
Old 10-07-2012, 07:54 PM
I replaced a lot of those modules back when the set was in warranty, and even after they were out of warranty. They had a massive failure rate when they were first introduced.
Zenith just sold the whole thing and you sent back the core as I recall.
Those stupid interconnect cables, the clips used to break easily when they were new, I wonder how they are 30+ years later?
Old 10-07-2012, 08:23 PM
tv beta guy
Guest
Posts: n/a
That is what I keep reading on here is how problematic these modules are....
Those interconnect cables on mine are still in tact.
Old 10-07-2012, 11:17 PM
This place lists a used 9-160-05A if that will work.
http://www.kenselectronics.com/lists/zenith.htm
This place also lists them
http://www.relaypoint.net/~arctv/parts/index.html
No idea of how reliable either of these are so use at your own risk.
Old 10-07-2012, 11:23 PM
tv beta guy
Guest
Posts: n/a
I've been reading the forums... will an odd numbered module swap with an even numbered? Or will I need to make modifications?
I kept reading that an 04 will swap with an 06 will swap with an 08.
Old 10-08-2012, 01:24 AM
jstout66 jstout66 is offline
I have a Zenith Cross Reference Guide, and go figure.. it doesn't list ANY sub for a 9-160-06.
In order:
9-160 Sub: 9-160-03, 9-160-05
9-160-02 Sub: 9-160-04 9-160-06
9-160-03 Sub: 9-160-05
9-160-04 - 9-160-06
9-160-05 - No sub listed
9-160-06 - No sub listed
9-160-08 Sub: 9-160-05
9-160-09 Sub 9-160-06
So, to add to the fun.. did your set come WITH the 9-160-06, or is the module in yours a sub? (the schematic will tell you)
Old 10-08-2012, 02:24 AM
The second place lists both a -5 and a two -6 so if they actually stock those numbers you should be set, if the price is reasonable at least.
