Old 02-23-2013, 10:42 AM
DavGoodlin's Avatar
Motorola Minion
There is a producer of bezels (old time reproductions? in CA) for Philco radios that sells through Radiodaze. Maybe they would comission one.
Old 02-23-2013, 10:59 AM
47'Plymouth 47'Plymouth is offline
I'd go for it...a bit pricey,..but worth itlet me know when ones availableJody
Old 02-23-2013, 11:58 AM
kx250rider's Avatar
REAL TVs have TUBES!
That would be worth having a new bezel made by CAD/CAM, and I bet it could be done on a low production scale. I know a hobbyist who is recently retired from a career in mil-spec machining, and he has "made" perfect reproduction laser-cut pocket watch parts, antique car parts, etc. He could probably do it, but I'd have to get his permission to give out his name. He just spent more on a hobby workshop in his barn, than it would cost to build a whole 5000-square foot house. He installed all the technology he knew at work, and has it all set up.
Charles
Old 02-23-2013, 02:31 PM
There may be a 3D printing option on the bezel, too. But no-one knows if that stuff will last 70 years, either.
I'm not any kind of qualified restorer, but that won't stop me from sharing a thought: Perhaps a thin sheet (1/16" or less) of aluminum, brass, etc. in the original outline of the bezel, with the original bezel aligned as required and mounted to the 'shim'. Paint to match original bezel as much as possible. Attach shim to original wood holes, (hiding the finish issue) and attach bezel to shim in a manner that allows 'creep' without 'crack'. That may be black plastic or nylon phillips machine screws in to tapped holes or soldered-on threaded plates, or the like. The plastic/nylon would give a bit, allowing original bezel to move without cracking more.
If the black nylon screw head looks out of place, then perhaps use a flat-head screw and affix a sacrificial black steel phillips head (only) to it... basically as decoration.
Yeah it's a lot of work, but you've got a pretty good head start overall!
Nice example.
Chip
Old 02-23-2013, 03:25 PM
I would put in a plea to at least ATTEMPT to do an electrical restoration, as well...You might get lucky & end up w/a WORKING pre-war TV...How KEWL would THAT be ?!?
Old 02-23-2013, 07:34 PM
vts1134's Avatar
vts1134 vts1134 is offline
Looking For Time
Originally Posted by tubesrule View Post
What are the brand and date codes on the tubes and crt? It would be interesting to determine how long the set was in general use.
Darryl
I've never read date codes on tubes before. Where would I find them?
Old 02-24-2013, 06:55 AM
vts1134's Avatar
Looking For Time
I was able to find some date code info on the net. I could only find out what the first two digits of the three digit code stand for. Every tube in both the radio and television chassis, except for one, are RCA branded and coded KE5, XE1, XE2, or XE3. That means 1938, and 1939 OEM for the first two digits, does the last number indicate month? The only exception in the set is the horizontal output tube which is branded National Union. The only coding I can find on that tube is an "F". I don't have a tube tester so I don't know how well used they are, but maybe the set was used so little that the tubes are all original?
Old 02-24-2013, 06:58 AM
tubesrule's Avatar
tubesrule tubesrule is offline
RCA codes of the era where 2 or 3 characters long. The first character was the year such as R-1939, X-1940, Y-1941 followed by the letter E for OEM, followed by the month; 1-Jan-Feb, 2-Mar-April, etc. The XE1 for example is 1940, OEM, Jan-Feb. The KE5 is 1943, OEM, Sep-Oct.
Converters for obsolete standards:
www.tech-retro.com/aurora-design/legacy.html
Old 02-24-2013, 07:05 AM
tubesrule's Avatar
Unless the National Union tube is new enough to be labeled under the EIA codes (247 would appear somewhere on the tube for NU) there's no way I am aware of to date it. The fact that all the other tubes appear to be original except the KE5, would suggest the set was not serviced much past the late 1940's.
Old 02-24-2013, 07:12 AM
tubesrule's Avatar
Larry Bordanaro has been very ill and it is uncertain if he will continue making reproductions. Ed (blacksmith) at Renovated Radios has done some bezels but both these guys need fairly good originals to start with since they do exact copies. They can create successive master to straighten and shape a bad original, but the worse it is, the longer and more tedious this becomes.
Ed has investigated 3D printers but none of them give a good surface finish so the entire part would need to be sanded and polished (if the material is hard enough to accept a polish) and if it is intricate this can be difficult if not impossible. CNC can't make these swirled plastic parts unless you can find some swirled plastic material to start with. A CNC part could be used by Ed or Larry to then make a mold to cast parts, but even a CNC part takes considerable amount of sanding and polishing to create the mirror finish.
Old 02-24-2013, 07:35 AM
Steve McVoy's Avatar
Reproduction pushbuttons are available here:
http://www.renovatedradios.com/parts.html#pushbuttons
There are a number of RCA radios that use similar bezels. The difference is that the TRK-5 bezel uses aluminum pieces around the eye tube and electric tuning light, while the bezels from other RCA radios either have no pieces or have pieces that are silver. It is easy to remove the painted pieces from the old bezel and put them on the replacement bezel, though.
Here are some of the RCA radios with similar bezels:
98T, chassis RC-386A
98K2, chassis RC-386A
97K2, chassis RC-351K
97T2, chassis RC-351K
96E2, chassis RC-351L
96K5, chassis RC-351L
96T7, chassis RC-351L
Old 02-24-2013, 08:36 AM
Geist Geist is offline
Hi All;
VTS1134, You should be able to find another member in the Area of where you live who has a tube Tester, that could help you, determine how good the tubes are.. I have one that would do the trick but I live way tooo far away..
THANK YOU Marty
Old 02-24-2013, 09:34 AM
vts1134's Avatar
Looking For Time
Marty-
I have a local shop in my area where I test all of my tubes so I'm covered there.
I have the reproduction pushbuttons ordered and they are on the way. Since I have to wait for the pushbuttons to arrive before I install the radio chassis and bezel, I'll put that on the back burner.
On to the television chassis. Looking over the underside of the chassis I can see that there was repair work done to the horizontal output circuit. That could account for the replacement horizontal output tube.
Can any one spot anything else out of place?
Old 02-24-2013, 09:59 AM
vts1134's Avatar
Looking For Time
The television chassis has suffered some damage. The fine tuning portion of the channel selector shaft has broken off.
I am able to turn the fine tuning control from what's left of the shaft, however it simply spins freely, the shaft must be broken internally as the fine tuning capacitor (C9) does not move. I thought perhaps the capacitor could be seized, which would account for the breakage, but I can adjust it manually.
I am considering a repair to this part of the set depending on difficulty, and whether or not an original shaft can be found, or the original repaired.
Old 02-24-2013, 11:34 AM
tubesrule's Avatar
John,
Those replaced caps are the horizontal deflection coupling caps and are always bad. They did take a while to go bad originally which suggest this set was used for quite some time. It's too bad that the original caps are gone as it's quite easy to restuff them with modern 3000V caps. You'll need to find caps of the correct size or cardboard tubes that can be dyed to match to use for restuffing.
The two large caps on the opposite side of the board with the yellow and green heavy wires going between them are the vertical deflection coupling caps are are most likely bad.
Your fine tuning control is working correctly. The shaft is supposed to turn freely. If you look at your picture of the trimmer cap, the aluminum piece on the end is cup shaped. The black rubber piece is attached to the end of the brass shaft that goes through the main tuning shaft and is shaped to fit the cup. To adjust the fine tuning you have to push in on the shaft to make the rubber piece turn the trimmer cap.
The fine tuning shaft can be fairly easily replicated although it's a little difficult to install since it's rather long and you have to remove the trimmer to get it in.
