Old 04-05-2013, 03:01 PM
this set came from the original owner in western mass
Old 04-06-2013, 12:04 AM
mstaton's Avatar
mstaton mstaton is offline
"Book em Dano!"
7 volts, not to high??????
7v is OK for a few hours
Old 04-06-2013, 06:03 AM
Firebird's Avatar
Firebird Firebird is offline
Had one when i was a kid, was a 1965.
Old 04-07-2013, 10:49 PM
BigDavesTV's Avatar
BigDavesTV
Very nice looking "Sliver-tone" Roundie! I like that cabinet style, too, Congratulations.
Old 04-08-2013, 05:24 AM
well im recapping and doing what must be done on these sets befor running it and hoping the crt produces a good picture still because the crt is original but the red gun is weak. on 6.3 testing the red is weak and the green, not passing the 300 mark but blue just gets over the 300. the color setting on my crt tester is higher heater voltage and using that setting the blue and green pass but the red still dont make it to 300 its like 260, kinda low. anyone know a simple way to check the boost rectifier, rather then putting it all back together only to find its bad and pull it all out again. what defines a bad crt in terms of emission readings with this red gun being at around 260 and 300 is good i tried 2 testers and get the same result . i have a newer bk tester but not going to bother trying that one since i got the same result from the other 2 testers. would i have to try to balance the color drives in setup maybe keeping the green and blue lower to work better with the weak red ? i let it run for awhile to bake but not any better. as much as i dont like using the rejuv i did on the red and green on the lowest and tried it twice and it did not get any better so i left it alone now.
Old 04-08-2013, 10:12 AM
Old 04-08-2013, 04:20 PM
David Roper's Avatar
console lover
1960 Panasonic
tvontheporch.com
Old 04-08-2013, 05:36 PM
that color control on this roundie is in the front and its called chromix, whatever the hell that is. besides that the red gun on the crt good is 300 or more but im only getting around 270 so i dont know how this will perform once i get it up and running. any ideas how the red gun would work out being low like this or even how long it may last?
Chromix was the same as chromatone in Magnavox sets.
Old 04-08-2013, 09:46 PM
marty59's Avatar
marty59 marty59 is offline
Dumont had "Color Fidelity".
