Old 07-03-2013, 05:58 PM
wiseguy wiseguy is offline
Old 07-03-2013, 06:54 PM
John Folsom's Avatar
You hyave not shown us the date code, so it is hard to say. The date code is a 3 digit unumber like 514... meaning 1955, 14 th week. Unless I am mistaken :-)
John Folsom
Old 07-03-2013, 09:52 PM
mstaton's Avatar
mstaton mstaton is offline
"Book em Dano!"
some have 4 digit numbers 55 14 etc at least that's how my cyp crt is
Old 07-04-2013, 05:39 AM
Old 07-04-2013, 08:37 AM
Originally Posted by wiseguy View Post
That is the only number that I can find on the base, which is why I thought I would ask, I thought maybe there is something hidden with the serial number.
I'll take a peek again after my Morning Jog
Look on the paper tags on the bell.
Old 07-04-2013, 10:59 AM
Steve D.'s Avatar
Steve D. Steve D. is offline
If I read the tube type # on the neck correctly, it's a 21AXP22A. Which is not original to the 21CT55 receiver. Still, the build date info would be interesting.
-Steve D.
Old 07-04-2013, 12:10 PM
Some RCA CRT's have the code date stamped on the end of the locating key.
Old 07-04-2013, 01:03 PM
Old 07-04-2013, 01:15 PM
Old 07-04-2013, 02:35 PM
Tim's Avatar
Tim Tim is offline
Your keyway number makes sense. One of my AXP's that I can easily get to now has a S/N of AC69535 and stamped 57-26 on the keyway.
Here is part of what Lud Sibley wrote about RCA CRT date codes. The number on our tubes seem to have an additional letter in the beginning and does not match his codes so it is hard to know how to translate it exactly.
Year letters were:
1944 H 1949 J 1953 T 1957 S 1961 N 1966 Z 1970 P
1945 A 1950 C 1954 X 1958 K 1963 F 1967 U 1971 Y
1947 N 1951 Z 1955 R 1959 H 1964 J 1968 T 1972 S
1948 F 1952 U 1956 Y 1960 A 1965 C 1969 X 1973 K
Note the ambiguous 15-year repeat of the letters, except for "P" and "R."
The month-number and year-letter sequence was reversed each month. For example,
"C6" designates Nov. 1950, whereas "6C" designates Dec. 1950.
FOR SPECIAL PURPOSE TUBES
High-value power and cathode-ray tubes carried serial numbers. The serial identification was a year letter plus a five digit number. The year letters for 1944-73 were the same as shown above for metal tubes, plus the following (reflecting the later demise of the Lancaster power-tube plant compared to Harrison).
1974 H 1977 N 1980 C
1975 V 1978 F 1981 Z
1976 A 1979 J 1982 U
The number part of the identification reverted to "1" at start of a new year, at least on
types like the 858B. On some types like 869B, the serial number substituted for a
date-of-manufacture code. (S. N. 27-1-1A, p. 3 [6-14-57 and 12-1-69]).
Tim
Old 07-04-2013, 06:57 PM
miniman82's Avatar
First Light: 1952-2011
Steve is right, that tube would have to be a replacement since it's the 'A' version. See the red dag on the inside? It has a resistance to it, so it can be used with chassis not having the series resistance in the anode lead. The 21-CT-55 had an extra anode lead with the resistors in it, the CTC-4 had them built into the HV tower connection on the chassis. These served as arc-over protection for the flyback, but when the 'A' version of the tube came out they were no longer necessary. Hence chassis using the 'A' version had no series resistors, as they were in effect built into the CRT. It would be a very bad idea to use a non-A 21AXP22 in a chassis without series resistors, there would be no protection at all from arcing.
Evolution...
Old 07-05-2013, 05:58 AM
Old 07-05-2013, 08:30 AM
Yeah I found out all about that maybe 15yrs ago when I was Really into the Vintage sets, the owners of this set said the CRT was Replaced a thousand years ago, I just wanted to know how to find the date code, I wonder how long these Tubes sit on a shelf before being sold to a Repairman back in those days
I don't think they sat on the shelf that long. There wasn't that many color CRT's made at that time.
Also other firms building color sets were buying RCA CRT's at the time.
Old 07-08-2013, 10:13 PM
earlyfilm's Avatar
Eternal Member
Does this also apply to B&W CRT's?
Where can I find the rest of his codes?
I had been wondering if any of my 5TP4's were replacements. All were from TVs manufactured in 1949 (although one carried a 1948 model number.)
No letters found, except on the neck glass. (NEB, JEC, MEB & unmarked)
However, the back of the light-brown bases carried open date codes:
9-39
9-48
0-35
0-43
Ouch! So at least two were replaced the first year!
Sorry for posting a B&W question in the color forum, but I guess there is precedence. When the 15GP22 and 15HP22 first came out and no service shop had a color CRT tester, the instructions to test either was to use the 5TP4 setting and wire up jumper clips directly on the CRT socket for each gun.
James
Old 07-08-2013, 11:39 PM
Tim's Avatar
Tim Tim is offline
Here is the document on Date Codes:
http://mysite.verizon.net/tubetronic...TE%20CODES.pdf
Tim
