Old 07-07-2013, 08:49 PM
jmetal88 jmetal88 is offline
Advice on transporting a floor model TV?
If someone else doesn't get to it first, I may be picking up this TV about 60 or 70 miles from where I live. Now, I've never transported a floor model TV, so I was hoping for some advice. Here's a picture of the set in question:
The plan is to pick it up while I'm bringing the pickup I'll be borrowing from my dad back to town before I move into my new apartment, and I'm pretty sure I'll have to transport the TV in the bed of the truck. So apart from wrapping it in a blanket or something, what's the best way to assure it arrives at my place intact? Should I try to keep it upright, or would I be alright laying it on its side? I'm hoping I won't need to remove the chassis for transport, but if I should, please tell me so! I haven't asked the seller what the model or chassis number is yet, so I don't really know anything about what's inside, but I love the look of the set so I told him I'd buy it if he still has it when I inquire again.
File Type: jpg 3F83J83H15Lf5Ha5M3d5qe3e301e7794117bb.jpg (36.5 KB, 210 views)
Old 07-07-2013, 09:09 PM
To me, standing upright is the best option, as that is the way the set is designed to be used. For the best security, face the screen forward, and if the truck has those loop anchor points at the four corners of the top edge of the bed (or if you can pick up a couple of them-cheap at auto parts stores), tie a rope or strap around the set from the left front anchor to the right front one. Ideally, you would check inside the cabinet first to be sure the chassis is held down by at least two of its original screws, too.
Second best position, if necessary, is to have the set face down, but then you need to have the chassis secured for sure, and you also need to add supports (2x4s maybe) under its corners or elsewhere to be sure it does not lean on the knobs or their shafts.
Old 07-07-2013, 09:31 PM
The truck does have anchor points in the corners of the bed that I was planning to use. It's good to know that face down is better than on its side in the event that transporting it upright is impractical. I'm hoping it's not all that tall so I'll be able to keep it upright, though. I might have to look in my dad's garage before I leave with the truck to see if he has any scrap lumber I could use for supports just in case.
Old 07-07-2013, 09:45 PM
egrand
Guest
Posts: n/a
Nice looking set. I would really try to keep it upright if possible. Put it in the front driver's side corner and strap it in at least two directions. Another good thing to take along is some sand bags and you can put them around the legs at the bottom. Main thing is to keep it from sliding or tipping, and take curves nice and easy.
Old 07-07-2013, 09:59 PM
hi_volt's Avatar
hi_volt hi_volt is offline
Vintage TV and Radio Nut
Also, make sure you leave clearance around the neck of the picture tube where it sticks out the back of the cabinet so it doesn't get pushed in or crushed. I'd use plenty of blankets and face the TV towards the cab of the pickup, making sure there's plenty of padding so you don't damage the knobs. If you can get furniture straps, that would be better than rope for securing the set. Good luck.
Old 07-07-2013, 10:03 PM
Thanks! I have at least two furniture straps available, I'll make sure to bring them along.
Old 07-07-2013, 10:07 PM
Thanks for the advice! I just really hope it's still there when I have the time to go get it. I'll have to wait almost two weeks before I'm ready to borrow the pickup for my move. The seller acted like he hasn't had any other interest in the set, though, so I'm hopeful about it. He's also trying to sell a bug-eye table model Zenith, but I'm not as interested in that one.
Old 07-08-2013, 05:20 AM
vts1134's Avatar
vts1134 vts1134 is offline
Looking For Time
Good luck on the new set...and greetings from Pittsburgh .
Old 07-08-2013, 10:25 PM
No matter how you transport it be sure to open it up and look for anything loose first!
Make sure the chassis is tightly mounted. Make sure there are no loose spare parts left by a repairer. If the high voltage section has a cover make sure it is fastened down and not just laying loose.
Old 07-08-2013, 10:56 PM
Alright, I'll bring along a few screwdrivers. Hopefully it doesn't use anything too unusual. The tabletop Zenith I have currently just uses Phillips head screws on the outside, and hex head screws on the chassis.
Old 07-12-2013, 09:47 PM
I think I called the guy just in time on this set. The Craigslist listing has actually expired since I contacted him, so if I hadn't done it right then I probably would have lost my chance! As of right now, I'm set to pick up the set next Friday at 7 or 8 in the evening, provided I give the guy a reminder Thursday that I'm coming for it. I'll probably ask him for directions then. Google Maps claimed to know where the address is when I searched for directions, but I have my doubts, considering when I searched the address by itself it gave me the 'vague dot' rather than the pinpoint.
Old 07-20-2013, 10:06 AM
I got it home safe and sound! The only damage that occurred during transit were a few minor chips out of the wood on the rear legs, but since other areas of the cabinet already had minor damage, the new damage doesn't look that bad. This thing is a lot bigger than I was expecting, though! Model number is D2460M. I'm afraid the pictures don't do it justice, though. This thing is absolutely beautiful, even with the cabinet damage (which I'm pretty sure I'll leave in place, at this point, although I might try to re-finish just the top panel).
My only problem now, though, is that I'm not sure I have enough space to actually work on it! It'll just have to serve as a decorative piece until I'm finished moving, then I can actually open it up and see if I have enough room to keep the chassis out and replace the capacitors. My new roommate keeps telling me I should put a flat panel screen inside it, and I just keep giving him that "Are you nuts?" look in return.
The guy I bought it from told me that, when he acquired it, he had plugged it in and was able to get a 'dim picture' from a VCR, so I'm hoping there's not a lot wrong with the set that replacing the capacitors won't fix. I guess it might be worth picking up a CRT tester/rejuvenator and perhaps some proper alignment equipment just in case.
The thing that surprised me with this set when I looked at it was how it was marketed as a Hi-Fi model -- it actually has two speakers in the bottom, as well as treble and bass controls!
Old 07-20-2013, 10:27 AM
I wouldn't waste money on a CRT tester or alignment equipment at this stage. Many TVs can be successfully restored with nothing more than a soldering iron and a simple multimeter (which tests resistance, voltage, etc.).
This article tells how to test whether a tube is a dud using a multimeter:
http://antiqueradio.org/FirstStepsInRestoration.htm
Many TVs come back to life with nothing more than recapping and basic cleaning (tube pins, controls, etc.). If you don't have a lot of spare room or money, I'd hold off on buying stuff that you might not need.
This page lists various TV restoration articles that you might find interesting in a general way, although none of my sets is exactly like yours:
http://antiqueradio.org/televisions.htm
Phil Nelson
Phil's Old Radios
Old 07-20-2013, 11:17 AM
Phil Nelson
Phil's Old Radios
Well, this'll be my second time fixing a tube TV, so I was mainly thinking for the future if this becomes a major hobby for me. For the first set I worked on, I used a lot more guesswork than I should have and ended up throwing off the IF alignment because I didn't know what I was doing, which is what got me thinking about getting more appropriate testing equipment. My dad has a general-purpose tube tester that I used when working on my first set, but it has no capabilities for testing a CRT.
I do really appreciate those links though, and I'll be sure to give them consideration when starting work on this set!
Old 07-20-2013, 12:09 PM
I realize you've achieved your stated goal, but here are a few more tips on moving fragile things for future readers:
If you can move it in a passenger vehicle, the ride will be much smoother for your treasure. Minivan with the middle seats removed gives you secure, weatherproof storage with appropriate hold-down locations.
Use non-elastic hold-downs if you're not resting the device on a cushion/absorber. So, if you're tied to the vehicle, make sure it can't move, and then "snap back" due to bungee cord elasticity. Better to be secured so there's no movement possible.
If you are placing it on cushions, then bungees may be appropriate, if loaded correctly.
If you're moving one small item in a truck that rides harshly, load it down with some other well-secured, heavy items. That way the suspension is more forgiving. Same with trailers -- a good load will help control bouncing and harsh impacts.
And finally, like noted in earlier posts, spend most of your effort on controlling sudden deceleration movement. Second, side-to-side. And finally, movement due to acceleration. The last one is the one that's most in your control.
Glad you arrived with minimal damage, and happy fixin'!
Chip
