Old 08-04-2013, 05:31 PM
kvflyer good luck with it , the amount of capacitors is nothing compared to some dumonts and rca sets , beware of mica looking or micamold caps that are really paper/wax type values like .001 , one i missed in my set caused the whole vertical to not work.
Eric where do they sell that stuff ? wont hurt to apply it maybe it will cure it .
btw those pics show the set not totaly adjusted as far as vert and horz and the contrast is up all the way , shows that the crt had better days but watchable with a brightner , without it the image slowly gets a little darker and less blacks or if started up from being cooled off its just darker and less blacks.
mike
Old 08-05-2013, 12:22 AM
oh now you can see my test pattern in the picture - the sonar circle in the begining of voyage
mike
Old 08-06-2013, 10:13 PM
cbenham's Avatar
cbenham cbenham is offline
Originally Posted by kvflyer View Post
Mike, BTW, my porthole had a 10 amp, yes, you read it correctly, 10 amp fuse in the horizontal section. I think it would be what one would call a "NoBlow" fuse...
I would replace that 10 amp fuse with what ever is noted in the schematic or on the chassis. Usually a 0.25 amp type.
The 10 amp fuse could cause a fire and that would not be a good thing at all.
Old 08-16-2013, 10:35 AM
John Marinello's Avatar
<-- "Byron"
Your pictures look keystoned, so you likely have shorted windings in your yoke.
Old 08-16-2013, 11:30 AM
Looks more like perspective effect from the camera angle.
Old 08-16-2013, 09:09 PM
yes odd angles , it is laying on its side and difficult to take pics head on
