Go Back   Videokarma.org TV - Video - Vintage Television & Radio Forums > Introductions
Old 09-29-2013, 10:26 AM
CrimsonGlory CrimsonGlory is offline
Newbie with(out) a cause
Hello everyone. I just recently registered to this fine message board. While I intend to lurk more than post, I figured I'd make an introduction regardless.
I'm a member of your companion forum Audiokarma, and an avid thrift store hunter. A few months back I came across a nice video offering from JVC at a local Goodwill for $8 and some change. I got it home and started doing some homework on it. At that point I found a couple of forum posts from here that briefly touched on this particular piece, so I figured I'd register to see if I could learn more.
JVC HR-S8000U is the model. Pardon the awful photography.
Old 09-29-2013, 03:00 PM
Welcome, & that looks to be a piece that was prolly pretty close to TOTL in its day...I got an S-VHS deck right before the curtain fell on 'em, I don't think I ever used the "S" part/features of it...
Old 09-29-2013, 03:08 PM
Kamakiri's Avatar
Kamakiri Kamakiri is offline
Welcome aboard!
Old 09-30-2013, 07:45 AM
DavGoodlin's Avatar
Motorola Minion
That does look impressive indeed. I hope there is not much wrong with it.
It looks close in feature level to the Sony SLHF-800, a TOTL Beta machine. The store I worked for sold exactly one of them in comaprison to dozens of SLHF-400 s
I bet there's is not many like yours.
-Dave G
Old 09-30-2013, 08:31 AM
I feel welcome already.
If I throw a tape in and press 'play,' it does its thing. I do have to admit it's a little sluggish but it does work. Between that and one of the bulbs in the display being a bit dim I don't see much wrong with it. I'm sure it will require replacing all the rubber inside at one point, but I wouldn't know where to turn for that. I did a little bit of looking around for a source of replacement rubber for this particular model, but I'll more than likely have to have the belts out first.
Old 09-30-2013, 02:25 PM
Nice machine.... S-VHS machines are very cool, and even without the S-VHS tapes, they record, and play a better picture than most other regular VHS machines. I have a few JVC 3000 series S-VHS units, they are the cheaper ones, I kinda wanna say 3810, or 3820, I would have to move it to see, But anyway, new belts if you need them can be had, just so a little looking on google... Nice to see ya-
Old 09-30-2013, 11:20 PM
tvtimeisfun tvtimeisfun is offline
Hello welcome to the best site for early tv items hope you grab ahold and fly with us to tv heaven. great vcr by the way...Timothy
Old 10-02-2013, 03:06 PM
Nice deck. Closest I've come to that in the thrifts is a NEC that is probably a tier below that features wise.
A lot of S-VHS machines appear at the local thrifts. I've bought several, but only the S-VHS-ET machines actually got much use(because the ET decks can record S-VHS quality on regular, cheap VHS tapes) before I started time shifting with DVD recorders.
Old 11-08-2013, 06:18 PM
TVTim's Avatar
TVTim TVTim is offline
Welcome!
That is a really cool VHS. Love it.
Old 11-08-2013, 06:43 PM
Winky Dink's Avatar
Winky Dink Winky Dink is offline
Welcome
I was very big on VCRs since about 1980. This similar model is gathering dust in my garage:
This is an HR-D630U. Functionality is probably similar, and I have the owner's manual. If it would be any help, let me know.
Winky Dink
Damn the patina,
Full speed ahead!
Old 11-08-2013, 06:47 PM
davet753's Avatar
davet753 davet753 is offline
David Thomas
Those machines were pretty slow when they were new, so I'd say time (and deteriorated belts) aren't helping things along.
From a mechanical view, those machines were very well built. I do, however, remember they were very slow to go into play mode. I say if you were to clean off all the old gummy grease from the gear set and re-lube it you would likely notice some improvement. If you do, don't forget to put a little grease on the tracks the guide posts travel in.
Old 11-08-2013, 06:54 PM
davet753's Avatar
David Thomas
I used to use PRB (Projector Recorder Belt Co.) for belts and rubber parts. PRB line is a division of Russell Industries (lots of the old techs are familiar with them). Most of the independent suppliers used to carry them, way back when there were still independent parts suppliers around
Just google "PRB Line" and you can get to their website.
