Old 10-09-2013, 05:35 PM
mjrossit mjrossit is offline
Looking for vintage Hitachi Antenna
Hi there,
I have a Hitachi TWU-73 Black and White TV with an antenna that has seen better days. I'm sure it works fine, I just want to replace it for cosmetic reasons.
Does anyone know where I can find an exact replacement? Otherwise I guess I can go with a universal replacement. The part number in the manual says VHF Antenna - 2750011
Thanks
Matt
Old 10-10-2013, 08:06 AM
Odds are you wont find an original. Depending on the size
of the base an RCA or GE stud mount will work fine & look
almost the same. We used them as a universal on many sets.
Sony & a few others used it also. They were common before
most went with plug-in antennas.
Old 10-10-2013, 09:15 AM
marty59's Avatar
marty59 marty59 is offline
I would be helpful to see how it's mounted on the inside.
Old 10-10-2013, 12:25 PM
Here's a shot of how the antenna is mounted on the inside.
Thanks,
Matt
Old 10-10-2013, 12:42 PM
lnx64's Avatar
lnx64 lnx64 is offline
My hitachi uses two of those and only has one.
What's wrong cosmetically? What I see in the pic you posted in the original post, is repairable.. I've polished metal even with toothpaste.
Old 10-10-2013, 01:03 PM
Aside from the metal that needs polishing it has a dent in the middle and the tip is broken off. It's very hard to extend it.
Old 10-10-2013, 03:41 PM
Jon A.'s Avatar
Jon A. Jon A. is offline
Don't mess with Esther.
No worse than the situation with my 1983 RCA portable I suppose, it's missing its antenna mast altogether.
Old 10-10-2013, 10:55 PM
Several styles on the 'bay... perhaps something like this:
http://www.ebay.com/itm/UNIVERSAL-PO...item19e339e1aa
not affiliated,
Old 10-12-2013, 12:20 PM
Steve D.'s Avatar
Steve D. Steve D. is offline
Go to your local Goodwill store, or one like it, and select from the dozens of analog TV's one w/a similar antenna. Probably cost you $10.00 for the set.
-Steve D.
Old 10-14-2013, 03:43 PM
Well, I decided to go with the metal polish idea. First I took some very fine grit sand paper and lightly sanded off the speckles. It came out surprisingly shiny. No dull finish or anything. Then I used some metal polish and a couple drops of oil. So it looks brand new except for the top piece missing and a slight dent in the middle. I guess I'm happy with it for now. I watched a few episodes of Gilligan's Island after cleaning and re-capping the circuit board. Came out great.
