Old 01-19-2014, 01:33 PM
prkohlwey prkohlwey is offline
unknown tv
I hope you can help me with this one. I can tell you it says aug 1949.
Old 01-19-2014, 01:45 PM
Looks like an Emerson model 600 or 639 to me.
Edit add:
Pix: http://tvhistory.tv/1949-Emerson-600.JPG
Thread: http://www.antiqueradios.com/forums/...t=0&highlight=
Old 01-19-2014, 03:36 PM
Thanks that shure looks like it.
Paul
Old 01-20-2014, 11:40 AM
earlyfilm's Avatar
Eternal Member
Paul,
I agree, this does look like a Emerson 600/639.
These often were supplied with a bakelite case that often will be destroyed in shipping, so an unattached chassis does not surprise me.
I have an unrestored one with bakelite cabinet, that I bought simply to get a good 7JP4, but I took pity on the little critter and have decided to restore it. A check resistance check indicated there was no short, so I brought it up with a variac in series with a 10 ohm, 25 watt resistor, while monitoring the voltage across the resistor and the set worked as-found!!! This won't be done again until I get ready to recap it. If you need anything measured, just holler!
By the way, there is a Sam's schematic for this set at
http://www.earlytelevision.org/tv_sc..._diagrams.html
James
Old 01-20-2014, 01:30 PM
Wow! I have never seen this set in a bakelite case (mine is the wood model). I bet that it is really neat looking, could you perhaps post a picture?
Old 01-20-2014, 08:56 PM
Thanks for the replies. I did plug it in and nothing happened the tubes warmed up but no high voltage. I do have the schematics so while I'm waiting to find parts for my hallicrafter I'll start on this one.
Old 01-21-2014, 02:00 PM
earlyfilm's Avatar
Eternal Member
Is my face is red! It is not bakelite. I just pulled it out of its storage box for the first time in 15 years and think I was confusing this cabinet with another set.
I've owned this 639 since the mid-1990's, when we still lived in Dayton, O. It was found in a pile of stuff that did not sell at a rural estate auction. We had missed the auction, but spotting it there, I asked if it was for sale and the guy said "Make an offer."
I said $5.00 and he replied "make it $15 and its yours", so it followed us home. At the time of purchase, I just wanted the 7JP4, but after noticing that all tubes were marked "Emerson" and the set looked 100% complete, I carefully powered it up with my variac, and much to my surprise it worked. (The CRT is unmarked, unless it is hidden under the shield or brackets.)
The set has a wooden ebonized frame around the gold plastic front. The rest of the cabinet is shiny-finished 1/4 inch plywood, with a dark oak stain that hides the grain instead of enhancing it.
Here is a picture of the same model, but the set pictured has the cabinet sides incorrectly colored.
http://www.tvhistory.tv/1949-Emerson-639-7in.JPG
BAnderson's 639:
http://www.flickr.com/photos/7003980...7627253341517/
The color of Bob's cabinet matches mine, his set shows the wood grain, while mine, you have to look closely to see the grain.
James.
Old 01-22-2014, 10:54 AM
pallophotophone pallophotophone is offline
Check the low value resistor in series with the selenium rectifier. It's almost always open due to corrosion- especially if there is green at the point where the leads enter it.
