Old 03-25-2014, 06:50 PM
1966C10's Avatar
1966C10 1966C10 is offline
Magnavox console tuner glass D150534 needed
Had a little mishap with the tuner glass in the Magnavox 353 console I am working on and cracked it - its a longshot but maybe someone on here has one or something very similar laying around. It measures 13 by 4 1/8 and marked with D150534. Attached is a pic of the glass.
Old 03-25-2014, 08:39 PM
Reece's Avatar
Reece Reece is offline
If you can't find one, what you could do is remove it, clean it up, and scan it. Be very careful cleaning as the paint can come off. Use plain water and try in one corner first. Scan it and Photoshop (or other program) the crack out of it. Make test prints on plain paper to make sure the size is the same as the original. Dump onto a flash drive and take it to Kinko's or = and have them print it on clear plastic. Sandwich the plastic between two pieces of acrylic such as used in storm doors. Seal the edges with aluminum tape. I've done the same to save a bad dial glass and it came out fine.
Reece
Old 03-27-2014, 05:33 PM
1966C10's Avatar
Looks like I found one on another site - thanks for the idea, I may do one up that way so I have a backup in case I have another mishap
Old 03-27-2014, 06:25 PM
Reece's Avatar
Great you found one. At least make a scan of it when you get it just in case.
Reece
Old 03-28-2014, 08:39 AM
1966C10's Avatar
Yes I will... Thanks again for the suggestion
