Old 04-17-2014, 06:16 PM
Old 04-18-2014, 08:40 AM
bigaudioal's Avatar
That's an interesting theory, but not sure it applies to my situation. My modulator has been working fine for a year. Just within the past three weeks has the scrolling bar symptom started - so I don't think it is a grounding issue.
I will see if replacing the 'lytics fixes it, and if not go from there. Waiting on the caps from Mouser along with a bunch of other parts.
Thanks for all these theories, as it gives me a good road map to follow if the first "fix" accomplishes nothing.
-Al
Old 04-21-2014, 11:18 PM
bigaudioal's Avatar
Recapped agile modulator tonight and scrolling bars GONE!!
Two of the 4 caps had nasty corroded leads when I unsoldered them from the board. But none had actively leaked. That was indeed glue on the board from the last install of these caps. I was able to clean the glue off the board easily as well.
Thx to those who chimed in on this issue. Video here:
http://youtu.be/wgrp8HOewxs
-Al
Old 04-22-2014, 12:18 AM
Yay! I love simple solutions.
Phil Nelson
Phil's Old Radios
Old 04-22-2014, 06:41 AM
bigaudioal's Avatar
Phil Nelson
Phil's Old Radios
Me too!!!! Thanks for the info on your site too. Was very helpful!!!!
-Al
Old 04-22-2014, 12:29 PM
kvflyer kvflyer is offline
Fortunately, the symptom is very similar to the same problem with a B/W television. Scrolling black bars up the screen were usually failed electrolytic capacitors in the power supply. Of course, our modulators are not exempt!
Glad you got the problem solved quickly and easily.
What type of solvent did you use to remove the glue?
Old 04-22-2014, 01:20 PM
bigaudioal's Avatar
Turns out the glue was SO dried out, it flaked off with my finger nail completely. Did not need to use any solvents.
-Al
Old 05-28-2014, 06:45 AM
Kamakiri's Avatar
Kamakiri Kamakiri is offline
I've got a strange issue with my Blonder Tongue CAMS-60. It's probably been like this for a while, but it bugs me. It's not "terrible", but if there's something I can do to fix it, all the better
Is there a place on the board to align the audio signal? It's not the audio adjustments on the front. I get slight whistling "S"s from everyone on TV that sounds out a "sss".
