Old 06-14-2014, 07:19 PM
Kamakiri's Avatar
Kamakiri Kamakiri is offline
Been offered a free Quasar.....
Normally I don't consider stuff this new for myself, but this is kind of a neat set....perhaps someone can enlighten me on it
This is the message I got:
"Tim, we have a Quasar Console TV, model WU9428YP, with manual, the date on the back says 1985.. It has been in our garage since at least 2000, when my husbands grandmother died.. Not sure if it works.. But you are welcome to it, if you would like it... "
Worth saving?
Old 06-14-2014, 08:29 PM
1985 is long after the sale to Matsushita, so this must be a "Panasonic?"
Old 06-14-2014, 08:38 PM
rca2000's Avatar
rca2000 rca2000 is offline
Likely will have that chassis that EATS flybacks---and the fly is likely mounted on a vertical board bear the rear cover...
But if you like those--go for it. I do NOT like those chassis, nor do I miss them. hot, chintzy and flyback-killers, like a lot of 19*80's sets.
Old 06-14-2014, 10:34 PM
Jon A.'s Avatar
Jon A. Jon A. is offline
Don't mess with Esther.
Unusual appearance for its year, free and no more than 15 years on the clock, so why not? A real stripper set, less to go wrong.
Old 06-15-2014, 12:41 AM
rcaman's Avatar
rcaman rcaman is offline
i second his motion. i never liked those sets. actually hated to work one one.
steve
Old 06-15-2014, 07:58 AM
jstout66 jstout66 is offline
also, the picture tubes didn't last long. I had a late 80's/early 90's Quasar, that was a top of the line set. Had built in Dolby DBX sound. It had the best sound of any TV I've owned, but the picture tube went south when the set was less than 10 years old.
If I were you Tim, I'd pass......
Old 06-15-2014, 09:39 AM
Kamakiri's Avatar
Yep, I do believe I will.....
Old 06-15-2014, 07:31 PM
I am not as negative on the set as other BUT.
There is nothing exciting about the set. Its a bottom of line
mid grade TV. The cabinet is boring, it has no special features &
its not rare. If it has a STRONG CRT it may be worth getting for
the jug.
It leaves me, shall we say LIMP.
There is much better stuff out there for free.
Old 06-16-2014, 05:57 AM
Jon A.'s Avatar
The cabinet could use a bit more ornamentation, but it's too much that really bugs me. The set may not be rare, but it's not the ubiquitous RCA of that era and that particular feature set, or lack of special features may be hard to come by on one of these, sort of like an '80 T-Bird with vinyl top delete.
Old 06-16-2014, 07:09 AM
Kamakiri's Avatar
Funny you should say that, I had a 1980 Thunderbird with vinyl top delete
Old 06-16-2014, 07:48 AM
man.. I thought those 1980 T-Birds were the COOLEST cars when they came out.
Old 06-16-2014, 11:15 AM
Jon A.'s Avatar
Isn't that somethin'? Haha. I knew you had some Fox 'Birds but not that exact model. I had only ever heard of one other and I'm not even sure if it was an '80.
Old 06-16-2014, 06:16 PM
Dreamsbeard's Avatar
Dreamsbeard Dreamsbeard is offline
Worth saving?
Seeing as it has been sitting for a while...maybe the CRT is still strong? If you can get it for free it would be great to see it work. As for me I like 80's TV, and I think this one looks good, so I would grab it myself.
Old 06-16-2014, 06:21 PM
davet753's Avatar
davet753 davet753 is offline
David Thomas
I don't remember those being too bad. Quasar was always popular in my neck of the woods due to a strong wholesale distributor nearby, so we worked on plenty of them.
Old 06-16-2014, 06:31 PM
I think the flyback number was TLF14423F and the same chassis was used in some GE televisions. On just about every one of these that came my way; the CRT was weak and the flyback, along with the NTE89 horizontal output transistor, was bad. Also, the PC board chassis was garbage and there were always bad solder connections on the power resistors and other heat generating components.
