Old 09-29-2014, 04:48 PM
Dreamsbeard's Avatar
Dreamsbeard Dreamsbeard is offline
1986 Hitachi 25'' console.
Evening fellow VK'ers,
I recently picked up this nice Hitachi console television, and I was wondering if anyone could help me find the part# for the flyback? Normaly I would simply check the flyback for it but it seems the number faded/is nowhere to be found, but here's the catch : the television model and the chassis # are canadian, so they don't show in sams.
Can anyone help me ID this set?
Thanks!
PS if anyone is interested the canadian TV model is TS6460 and the chassis is G6NU2
Old 09-30-2014, 11:58 AM
Findm-Keepm's Avatar
Followin' the Rules...
Looks like a CT2561, based on the parts location. I have a service manual in TIFF format, 3 Megs, so it won't post here. PM me your email address if you can accept large attachments. Flyback is a 2434641.
Cheers,
Brian
USN RET 22YRS (Avionics/Cal)
Old 09-30-2014, 01:16 PM
PM sent!
Thanks!
Old 09-30-2014, 03:06 PM
Two speakers? Actually, a CT2562.
Cheers,
Brian
Old 09-30-2014, 04:15 PM
It's in the small details...hehe
Wait, does that means that the TV drives 2 speakers with the same amp as the 1 speaker model? Might explain why I have to put the sound setting at least about 50% of the range to have a decent sound.
Thanks!
Old 09-30-2014, 04:28 PM
Jon A.'s Avatar
Jon A. Jon A. is offline
Don't mess with Esther.
It is actually a mono model right? If it is and the speakers are wired in series, more power would be used to drive them if the impedance of each isn't any lower than one in a single-speaker model.
Old 09-30-2014, 04:39 PM
Good thinking there Jon,
The speakers are actually wired in parallel (thats what I think you meant), but as you suggested, its total impedance is probably lower than the same speakers connected in series. But I think the amp still has to drive them both...so all in all if both are 5.5W , the amp has to put out 11 watts to drive them both, and only 5.5w to drive only one. Am I making sense?
Old 09-30-2014, 04:58 PM
Jon A.'s Avatar
Wattage is just the power handling of the speakers. Driving them with a higher-wattage amp could blow them. It's the impedance that matters more here. Parallel wiring would halve the impedance of each speaker, so for example two 8-ohm speakers would be required for a mono circuit that requires a 4-ohm load. No extra power would be needed to drive the speakers.
Old 09-30-2014, 08:10 PM
rca2000's Avatar
rca2000 rca2000 is offline
I see ONLY ONE transformer-couple discrete amp in this typical 1980's hot chassis, and I DO NOT think it could produce 5W cont. The amp is near the rear of the chassis...only ONE channel. You can see it on the right side of the tuner. Those 2 sinks on the outs are NOT big enough for that sort of power. More like 2.5 W cont. And that would be consistent with many 80's model non stereo sets.
This actually looks to be older than 1986 chassis wise, more like 1982 or 83. By 86--stereo was becoming pretty popular on larger sets.
Old 10-01-2014, 05:35 PM
I see, maybe this was of a sort of middle range set : 2 speakers, nicer finish, but older tech...
Old 10-01-2014, 06:32 PM
So this is a hot chassis. Would you recommend that I buy an isolation transformer before I try to redo convergence on it? As you can see I am pretty new a this.
Old 10-01-2014, 08:04 PM
rca2000's Avatar
I do not suspect if has much to converge--I am sure it has an in-line tube I do not recall ANY set later than maybe 1983 using a delta tube. Even if it did--doing convergence should not require using an iso. Only of you do some WORK on it--will that be an issue, or are on a concrete floor or such while playing with the chassis.
Old 10-03-2014, 06:16 AM
Well I did a quick clean and balance of the 3 guns(they where quite low and the red was smearing) and that seemed to throw the blue gun out of wack. The red and green are still properly converge, but the blue is now completely misconverged. If I remember correctly, the first two rings on the crt neck are for purity, and the others for convergence right?
The clean and balance also threw the grayscale off with a green tint, but after tinkering with it for 15 mins, it came back ok (it was perfect before). It was the first time I did a grayscale adjust, feeling proud of myself right now
Old 10-04-2014, 11:58 AM
As I was reading this article :
http://personalpages.tds.net/~rcarls...s/converge.txt
I came upon the section about convergence, and the article says that the blue gun can only be ajusted alone in an horizontal axis...is that true? As stated before the only gun needing adjustment is the blue one, and it needs to come down on a vertical axis...is there a way of only adjusting the blue gun that way, or do I have the play with the other guns as well?
Thanks!
Old 10-07-2014, 03:29 PM
Thanks!
Dunno the arrangement Hitachi used, but here's the typical magnet arrangement - the purity rings are closest to the funnel (farthest from the clamp), and then you have the two sets of magnets - aft (closest to the CRT socket) is the 6 pole, and in the middle is the 4 pole. The attached images explain it better than I ever could.
Cheers,
Brian
