Old 11-08-2014, 02:59 PM
Rod Beauvex Rod Beauvex is offline
The lead ear.
How about a Philips console? (now with chassis #)
Still wanting an upscale console. Found another one at the same thrift store.
This one is branded a Philips (Rather than Magnavox). 25 in or so. DBX sound. Unlike this Quasar mentioned a few weeks ago, this one won't even turn on.
Not sure of the model number (stores is closed now) It's not one of the usual Magnavoxes that had the onscreen menus, like the models that have the display and status buttons that Magnavox sold millions of. This one seems to be slightly older as far as I can tell. Similar though, but still different.
Tubes and Fly backs ok? I know the aforementioned Magnavoxes tended to have some problem, and I wonder if it affected this Philips unit as well. I liked the curved design, but it needs refinished, and one side lost its cloth speaker cover.
Is it worth looking at?
Old 11-08-2014, 04:05 PM
Best to get the chassis ## off the back, model dont help.
Symptom of "dead set" up till the early 80's was a gravy job,
afterwards it became increasingly bad news the newer you got.
Have to deal with complex switching supplies & bad flybacks.
Not sure what you wish on your upscale set but many very nice
modern style sets were made through the mid 80's that are
much easier to deal with. If you dont need MTS or a big jack pack
there is a lot to choose from.
Old 11-15-2014, 01:28 PM
The lead ear.
Model: 27H327-SA01
Chassis: 27c9-16
Manufactured 9-1987 in Greenville, TN
Worth looking at or avoid like the plague?
Old 11-15-2014, 04:09 PM
Originally Posted by Rod Beauvex View Post
Model: 27H327-SA01
Chassis: 27c9-16
A good set BUT with the "dead set" symptom probably best to
avoid it. Either something in the HV failed or the switching
supply failed. If it were free & you can get rid of it for free
it would be a good learning tool. Of course sometimes you
get lucky & its a fuse, cold joint etc but dont count on it !!!
This IS from the NAP family, Sylvania, Philco, Magnavox,
Phillips. Not a true Phillips, IIRC you are in Canada & IIRC
Phillips sold there own sets there once.
Old 11-15-2014, 05:08 PM
The lead ear.
I live in the US, not too far from where the set was made, actually. About 30 minutes.
I'm not averse to replacing capacitors or tracking down a bad voltage regulator. Reflowing solder joints isn't an issue either. (I probably would be recapping it regardless.) As long as it isn't running on borrowed time by having a possibly dying flyback like the Quasar I asked about.
Old 11-15-2014, 05:41 PM
Findm-Keepm's Avatar
Followin' the Rules...
I wasn't aware that Philips sold sets with the Philips badge at that time - most I've seen were post 1992 sets. C-9 chassis isn't all bad, but watch out for the white flybacks, the 1 ohm resistor failures, and the 160v caps. I'd nab it if the CRT was good.
Brian
USN RET 22YRS (Avionics/Cal)
Old 11-15-2014, 05:52 PM
The lead ear.
There are two somewhat later model Magnavox sets. One needs convergence, the other had sound problems, but they appeared to have nice bright CRTs, which is what prompted my thread about CRT swapping.
Old 11-15-2014, 06:26 PM
Some NAPs had bad saw filters C-6 IIRC. No big deal if you can find one.
Its a lot to do with finding parts. Again C-6 IIRC you kept a
list of parts to order OEM if the power supply was out. When you
called it in often they would rattle off the ##'s before you could
read them off.
FBT's were a problem along with cold joints in the hoz out
that caused the PCB to brew up. Most the C series chassis were solid
except the C-3 IMHO. Later in the 90's they built some stuff
I hated along with some good stuff. Like I said getting rid of the
body is a big deal to me. Even in N.H. you gotta pay to junk a TV.
Other than that take almost anything thats free & learn from it.
OK being from US, got you confused with someone else.
