Old 12-18-2014, 06:14 PM
Penthode's Avatar
Penthode Penthode is offline
I would not consider using a time base corrector specifically to remove macrovision. A timebase corrector is designed to address the variable write and read head to tape velocity variations which leads to playback time base error on video tape. It may as an option, include means to blank lines in the Vertical Blanking Interval but there is no guarantee as this is not the device's primary purpose.
In the old days of analog television broadcast, a video processing amp was inserted at the output of a studio production video switcher or the output of TV station feeding the transmitter. The processing amp would re-insert horizontal and vertical sync pulses and color burst and would generally include the ability to blank unwanted lines. Whether the Time Base corrector or Processing Amp devices can blank the macrovision lines immediately after the vertical sync is another question. The manufacturer may have obliged us by including this extra feature.
I personally would tend to avoid a timebase corrector as they often degrade composite video quality. The time base corrector would unnecessarily decode the NTSC chroma, the luma and chroma would be digitized, then re-clocked and then go through digital to analog conversion and then the NTSC chroma would be re-modulated. The quality of the resultant video depends upon the cost of the Time Base Corrector. The Processing Amp is perhaps a better choice as it would only replace the video sync and the color burst: the active video will be untouched.
The simplest solution may be simply to build a device with monostables to blank specifically the macrovision lines.
Old 12-23-2014, 11:50 AM
miniman82's Avatar
First Light: 1952-2011
Originally Posted by Gregb View Post
I bought one of these and it works awesome!! The picture is free of that macro nonsense and crystal clear.
http://www.ebay.com/itm/Digital-Vide...item2a479e1918
Thanks Greg, just got it in the mail and it works! No more macro crap, and cheap too! Only question now is, what to do with this apparently useless TBC? It does have neat features like freeze frame and picture and chroma adjustments in it, but in truth I can't see retaining it. Anyone want it for what I paid? I think it was $100 shipped.
Evolution...
Old 12-23-2014, 12:23 PM
Findm-Keepm's Avatar
Followin' the Rules...
It would be interesting to see the internals of one of those - to see how close it is to the old Macrovision Scrubber circuits we used to build. Radio Electronics had a first-generation one in the Dec 87 issue - it works, but the second generation Macrovision (non-tape media) made it almost obsolete.
Brian
USN RET 22YRS (Avionics/Cal)
Old 12-23-2014, 09:05 PM
miniman82's Avatar
Probably uses logic gates to strip the original pulses and replace them, there's not much inside it I can tell you that much. A power supply, and a few IC's is about it.
Evolution...
Old 12-26-2014, 12:40 AM
Dude111 Dude111 is offline
Analogue is Awesome
I'm at a loss, I just wanna watch a damn movie!
I wanna watch them also AND THAT MACROVISION CRAP MAKES THEM LOOK BAD!!!!
I have a 1997 movie on VHS called 'HOUSE ARREST' that has this crap and the video looks NOT AS GOOD AS IF IT DIDNT HAVE THIS GARBAGE!!!!!
Does anyone know how to remove it?? (W/o using anything DIGITAL to do it)
Old 12-26-2014, 08:55 AM
miniman82's Avatar
Can't do it without the box!
Evolution...
Old 12-26-2014, 03:17 PM
Analogue is Awesome
Old 12-26-2014, 05:32 PM
miniman82's Avatar
Honestly it's $50 well spent, I just hope it lasts a while because it's certainly made in China...
Evolution...
Old 12-27-2014, 10:30 AM
Originally Posted by Dude111 View Post
The video is not processed digitally in this box, as far as I know. There certainly are pulse/timing circuits to fix the blanking interval.
Old 12-27-2014, 04:33 PM
It looks like the one in Radio Electronics counts lines, and switches a newly-generated vertical interval in place of the macrovisioned-one. So, the actual program material you see is unaltered, not digitized and processed. All the information needed to build your own seems to be in the article, probably including the artwork for the circuitboard. You can mail-order boards made on a one-off basis, and populate it yourself if the parts are still available.
It's quite likely that the $50 version does things the same way...
Chip
Old 12-28-2014, 02:19 AM
NoPegs's Avatar
NoPegs NoPegs is offline
The glass is -3dB.
Score one of the "stereo" RF modulators sold by Radioshack between 2000 and 2003. Somehow they more or less blatantly ignore macrovision.
Old 12-28-2014, 09:42 AM
Olorin67 Olorin67 is offline
does anyone know the model number of that Radio Shack modulator, I see a lot on ebay, but hard to tell which is which.
Old 12-28-2014, 09:48 AM
Ed in Tx's Avatar
Ed in Tx Ed in Tx is offline
Zenith Walton My 1st TV
Back in 2001 or so I bought 3 "Stereo 2000" modulators on clearance at RS. Is that the one? Only MTS Stereo modulator I recall ever seeing for sale at RS.
Old 12-28-2014, 09:51 AM
NoPegs's Avatar
The glass is -3dB.
No, this was the regular $29.99 modulator box at the time. It has composite and L/R RCA jacks and an S-Video jack (Screen-door on a submarine!) on it, and the only thing up front was a red LED. I'm gonna go dig through some things and see if I can't scare up the part number for us. (I worked at the shack from 2002-2005.)
Old 12-28-2014, 10:01 AM
Ed in Tx's Avatar
Actually it is called a "Theater 2001" stereo modulator. I had to go look to refresh my memory. Cost was way more than $29.95 for a true MTS stereo modulator back then, more like $200-300. I don't know if it removes the copyguard junk.
