Old 02-14-2015, 09:33 AM
columbia columbia is offline
CTC-9 Power Caps
I'm getting ready to re stuff the power caps in my ctc-9 Abington. As a replacement for the 160mf 250v caps, do most of you guys use a 150mf as a lone replacement or maybe two 80's? If you use multiple caps, is it dangerous not to use balancing resistors? Any personal experiences as to safest/best approach? Thanks
Old 02-14-2015, 09:42 AM
the same voltage and MF never less. 2- 250v caps @ 80MF in paralle will give you 250v 160MF, but not a good idea. if you cant get the same value as original, higher is the way to go both voltage and MF, never less. if there is a bleeder resistor between caps it should be put back as is was but adding to balance, ah no i dont think so. hope this helps.
Old 02-14-2015, 09:45 AM
Findm-Keepm's Avatar
Followin' the Rules...
just did a recap of a Silvertone for a cousin - I used two 100uf 250V caps in parallel for the 160uF input filter.. I used radial caps, stacked. it was a tight fit in the can, but worked great. The B+ went up only 4V over the Sams value, so it worked fine.
Most caps were rated at +80%, -20% tolerance, so there was a wide variance of value. Todays caps are more tightly rated, with +/- 20% tolerance - that's the "M" code on most electrolytics. So your 150 could have been as high as 260-270uf new, hence the 200uf will suffice just fine.
Only in series do you need balancing/sharing resistors.
Brian
USN RET 22YRS (Avionics/Cal)
Old 02-14-2015, 10:42 AM
Wow. Thanks great info. I would have never thought of two 100mf's but it makes sense. It gives me higher mF so it's safer. Thanks much guys!
Old 02-14-2015, 10:58 AM
stromberg67's Avatar
stromberg67 stromberg67 is offline
A while back I got four 160@350 from Mouser that i used on CTC-11 chassis. They were Mallory branded axials. They worked out fine. Hope the re-cap goes well for you .
Kevin
Old 02-14-2015, 12:12 PM
I'll check them out. Thanks Kevin.
Old 02-14-2015, 12:25 PM
Phototone Phototone is offline
In paralleling caps one does not need bleeder resistors, these are only needed in series connection of caps. That is what I always understood, anyway.
Old 02-14-2015, 02:51 PM
On lytics you can go slightly lower in capacitance and be fine because of the tolerance mentioned before, in fact going higher in capacitance can be bad in some applications...If the B+ is high to begin with or if it drifts outside of ~30% tolerance due to a value change then running the set that way for a prolonged period could have adverse effects (if the set even works properly that way).
Never go lower in voltage though! That can be even worse.
Old 02-14-2015, 03:06 PM
StellarTV's Avatar
StellarTV StellarTV is offline
150s are fine. Just make sure they're both changed to 150uF. The resulting voltage difference is negligible.
Old 02-14-2015, 04:13 PM
So Justin, are you saying to use two 100uF's in parallel? I got another good suggestion to use two 150uF's in parallel. I guess I'm a little confused. Wouldn't 100uF's put me out of the low tolerance range?
Old 02-14-2015, 04:16 PM
Correction to justin: I know you said 150's and not 100's. But do you think that would then put me too high in uF's? Thanks
Old 02-14-2015, 04:55 PM
StellarTV's Avatar
Oh no, I'm talking about just replacing each single 160uF filter with a single 150uF at rated voltage or higher.
Old 02-14-2015, 05:56 PM
Got it and thanks!
