Old 04-21-2015, 04:34 PM
rca2000's Avatar
rca2000 rca2000 is offline
WHY do germanium transistors test so WEIRD ??
So I have this rock-ola juke box amp to re-cap. I have done this....no real problems. BUT...when I went to check on the ckt. resistance on the negativbe B- supply rail (for the output stage-which is PNP GERMANIUM transistors) ..it checked LOW_-about 50 ohms or so across it. (n ONE direction ONLY though.) SO i checked the output transistors--delco PNP germaniums and they checked LEAKY...or so I THOUGHT. From E to C--they checked around 50 ohms or so ONE way...BUT the other way--they did NOT do this..the fluke meter just flashed "ol"... crazily. on diode test they do NOT show right at ALL.
B-to E and B to C checked similarly weird one way MUCH worse than the other. All FOUR transistors showed this. So I figured I had bad trannies. But this amp was supposed to WORK--it just needed re-capped to make it "whole".
THEN...I recalle that germanium transistors DO check different than silicons. I went and stole a couple of them out of a Zenith amp that is supposed to be working...and they checked about the SAME way.. Somewhere about 125 ohms or so one way E-to C and high the other way.
WHY do they show like this Normal si trannies do NOT . Is this normal for them ?
Old 04-21-2015, 05:47 PM
Yes, Ge transistors are not quite the clean crisp on-or-off like the Si transistors.
Ge's are better looked at in a circuit than taken out and tested.....
You can do something like this....
https://www.youtube.com/watch?v=dnvi2OFDLBk
Old 04-21-2015, 06:27 PM
Germaniums also have a different conduction threshold voltage, lower than the .7 of silicon devices....IIRC it is .5 or close.
Old 04-21-2015, 10:22 PM
DavGoodlin's Avatar
Motorola Minion
Using the diode test on most DMMs gives the value of this voltage drop. Most Si devices, when reading forward across a junction, show about .6 -.69 volts.
A 1959 car radio I worked on recently had a (good) Delco DS-501 transistor for the output. Anyway, it measured much less and inconsistently on my Fluke, like Tom says.
-Dave G
