Old 04-27-2015, 09:56 PM
tvcollector's Avatar
Well I posted results from what DaveWM asked a week ago.. He hasn't replied back to this thread.. I'm all ears.. I don't know where to go from here.. Tying to learn this stuff and if I can't fix it, than really is no point in having it.. My friend is not going to be around forever and if I can't keep these things going into the future than they will just be static items that are useless..
Old 04-27-2015, 09:58 PM
does the eff coil have a sharp peak?
Old 04-27-2015, 10:04 PM
did you go thru the horz sweep circ adj per the sams?
if so how is the shunt tube current (voltage drop across the 1k resistor, confirm the resistor value as well).
does the HV regulate well? (HV should hold constant while adjust raster brightness.
Old 04-27-2015, 10:05 PM
check the horz hold pot for continuity
Old 04-27-2015, 10:07 PM
is the line voltage 117v?
Old 04-27-2015, 10:09 PM
try subbing other sweep tubes esp the 6JE6 and the 3A3.
do you have the correct damper tube? make sure its a 6DW4 and not some 6C somthing
Old 04-27-2015, 10:11 PM
check the screen voltage and current of the 6JE6
does the focus coil look ok? (not burned up).
Old 04-28-2015, 03:31 AM
The focus coil looks fine.. The 6JE6 tests very strong.. I don't have another tube to put in it's place to see if there is any change.. I would have to order another one off eBay to do that.. The damper tube in it is a 6CJ3.. According to the sams, it's suppose to be a 6DW4.. But supposedly those are both the same tubes... Doing an eBay search most auctions list those tubes under both set of numbers.. There is no picture and HV only holds at 5000kv as I said in a previous post..
As for doing voltage checks and measuring across the pot, I will take the chassis back out tonight and do all of that..
Old 04-28-2015, 07:31 AM
maybe its a similar problem i had with my sivertone, after checking voltages at the 6bk4 shunt come to find out there was a shorted ceramic disc in the IF section that affected the bias voltage of the shunt tube and kept the hv from rising up to where it belongs. after checking the hv adjust pot and all other related voltages come to find that the shorted ceramic cap was in the shunt tube heater string that only would have affected the crt heater, shunt tube heater, and one other that i dont remember at this point because it took years to find this problem and i dont want to look back on it because it took so long to figure out. and let me point out that i would have never have found this problem if it was not for daveWM . so if anyone is going to get to an unusual problem with one of these sets it will be daveWM. take your time and be sure to check even everything even if something dont seem related and you will probably be surprised at what you may find as the culprit all along.like me i never would have thought that a tiny .001 cap would have caused the problems i had for so long. over the 4 years i had this silvertone i replaced so much, caps, resistors, done it all.
tube substitutions are the way to go with sweep circuits not tube checkers.
if you have another working roundie use those tubes.
you may be running off frequency, a scope or freq counter would tell you that.
try unpluging the shunt tube plate cap (HV there so hang out away from anything to prevent arcing). see if voltage comes up.
make sure yoke is plugged in correctly.
Old 04-28-2015, 07:37 AM
https://www.youtube.com/watch?v=CiaDjKUw0nU
this should be checked on ALL vintage tv's, it is now something I do routinely.
This is a preventive maint kind of thing, as it detects a defect that can destroy shunt tubes and CRT's if there is a problem.
Old 04-28-2015, 06:23 PM
Ok, I got the chassis out up on the table, and I'm getting only 244v at the HV regulator tube on pin 5, assuming it's the shunt tube, on the pin where the 1.5meg resistor is.. It's suppose to be 400v..
Old 04-28-2015, 06:32 PM
I'm measuring 0455v where the 1k resistor is on (R139) under the same tube which is HV regulator tube.. I cut the one side to measure the 1k resistor and it's only 181ohms on the meter.. Bad resistor.. Sams says voltage should be 410v, and the same on the other side of the resistor, but meter shows it a bit higher on the other side..
Old 04-28-2015, 06:57 PM
Adjusting the Horz EFF coil has made the current go down to around 197 - 205 ma under the HV output tube... I replaced the the 1k resistor and voltages go down to where they should be under horz reg tube..
Perhaps maybe the EFF coil could be an issue too seeing how it's right next to where the cap exploded..
Still under horz reg tube the voltages are still low at pin 5.. and HV probe at anode still shows only 5000kv
