Old 05-15-2015, 02:01 PM
Paul Knaack Paul Knaack is offline
Are you testing it in circuit? I'm pretty sure it has to be completely disconnected.
It doesn't look all that bad, I wouldn't give up on it until you get the set fired up and see if it works. Mine actually shot sparks out of it so I was pretty sure it was shot.
I also didn't have high voltage on first power up on mine. Turned out it was missing the phonevision jumper plug on the back of the chassis. It took me at least an hour of curcuit tracing to figure that out.
I'll dig through my stuff and see if I have any more maroon knobs for it.
Old 05-15-2015, 03:24 PM
Radiotronman's Avatar
Radiotronman Radiotronman is offline
You know, I never looked at that. I'll definitely see if it's that, I know what you're talking about.
Thanks,
Scott
Old 05-15-2015, 11:51 PM
I looked at the chassis tonight and it does have the phonevision plug in its correct socket at the back. Back to the drawing board. A friend of mine may have a replacement flyback for me. I'll recoat the picture tube once I see some progress. It's a 12lp4 and tests ok.
Scott
Old 05-16-2015, 10:02 PM
I've seen worse looking flys work, and nicer ones dead, and I've had my EICO fly tester lie to me occasionally....Case in point don't judge a book by it's cover. Get the H osc thru HV sections recapped and the osc. tuned, then you'll have grounds to declare it dead with certainty.
Old 05-18-2015, 02:50 PM
Tim's Avatar
Tim Tim is offline
Originally Posted by Radiotronman View Post
Eric,
That is an interesting idea! Now I've got to find a fly-1, because I don't have one. That will hopefully be easier to find.
This looks like one but condition unknown. No affiliation.
http://www.ebay.com/itm/121650338736...%3AMEBIDX%3AIT
Tim
Old 05-18-2015, 03:59 PM
That looks like one but there are a lot of them that look the same. If anyone has a 49 Magnavox Sams they could check and see what fly it used that should tell.
If it uses the same sweep tubes and yoke it'll probably work.
There were a lot of sets from 46-49 that used the Fly 1.
Old 05-18-2015, 07:59 PM
A friend of mine gave me a few flybacks that are listed as suitable replacements for my set. One being a fly-53. I will recap the horizontal section as suggested first, to see if any life is shown left from my original flyback. If still nothing, then I'll try replacing with one of these three.
Old 05-28-2015, 04:07 PM
Getting ready to recap the horizontal section and I notice that the Sams listed for this model doesn't even match. I can replace what I see in the set, but how do I know what the sand coated resistors are when the sand has fallen off with the markings?
Old 05-28-2015, 04:40 PM
Try this schematic, Rider 3 page 13-14. Wide band if revised chassis
http://www.earlytelevision.org/pdf/z...f20-rider3.pdf
This one matched my chassis.
Old 05-28-2015, 11:14 PM
Thanks for the help. I forgot I actually had a partial set of Rider's book, including that volume. I'll study it and see if it matches my set.
Old 06-05-2015, 07:52 AM
Ok,
So I'm beginning recapping and resistor checks on this set. Many sand coated resistors, luckily most still have part numbers on them so I can reference what it is on the schematic. There's one that is missing all of its coating. That should be fun tracing that part back. I'm going to replace as much as I can, with what I have on hand, then order the rest. Three electrolytic cans are hidden on top of the chassis, underneath the yoke assembly. So I had to remove them to access these cans.
Old 06-05-2015, 07:56 AM
This is the resistor in question, missing all of its sand coating. Another was like it, but still had the side with part number on it. That one was completely open. Yes I can trace them back on the schemstic, but it's a heck of a lot faster if I can look it up under the resistor part values on the schematic.
Old 06-14-2015, 09:49 PM
Ok,
I've replaced the few caps that I had left over from a prior set I restored. I placed an order for the remaining caps and some open power resistors that were sand coated. I also ordered the 20 watt power resistor that was completly open off of ebay by Clarostat. Now I sit and wait for the parts to arrive.
Old 06-19-2015, 07:12 PM
Parts Arrival
Parts came today, time to get busy!!
Old 06-19-2015, 10:08 PM
Cap replacement is coming along. I also replaced two of the sand coated power resistors. I'll finish them and replace the three electrolytic cans under the yoke assembly.
