Old 06-30-2015, 02:12 PM
Could be insufficient drive signal to the horizontal output tube. Do you have a scope ? Also I believe there is a 470K resistor on the second anode that may have gone way up in value. Could also be as simple as a weak 1B3 rectifier tube.
Old 06-30-2015, 08:27 PM
Radiotronman's Avatar
Radiotronman Radiotronman is offline
I already replaced that 470k resistor that was inside the 1b3 tube socket. I also tested my 1b3 tube and it tests good on my tester. I have the horizontal drive control at it's max setting and get as high as 5000v, instead of 10k.
Old 07-02-2015, 08:43 PM
I disconnected the doorknob cap, to see if it was shorted and pulling down the hv; but there was no change. I think I'm left with changing the flyback with a nos one a friend gave me.
Old 07-07-2015, 02:34 PM
Finally made the molding that was missing around the side louveres. Still working on the flyback issue.
Old 07-28-2015, 01:58 PM
Decided to take off the remaining flaking aquadag and spray on a new coat.
Old 07-28-2015, 03:50 PM
Picture tube is now recoated!
Old 07-28-2015, 03:53 PM
I found the little sliding focus range switch, which allowed me to make the picture sharper and much easier to view, but still only at 3000-4000 volts to the second anode. Still trying to figure out what's pulling that down....
Old 07-29-2015, 02:27 AM
Nice to see your progress.
Old 08-02-2015, 02:52 PM
Flyback help!!
I'm wondering if I should try my zenith flyback replacement. This one cleaned up pretty good, but still wonder if it's weak? Do flybacks become weak or is it a situation where they either work at or not?
Old 08-02-2015, 04:55 PM
Could be going south, but I'd make sure all the horizontal adjustments, B+ voltages, and H output tube voltages/currents/waveforms are right first.
Old 08-02-2015, 05:19 PM
Well if you have a replacement then swapping it in to see if that fixes it isn't all that hard, but first, have you swapped the 1B3 Rectifier yet?
Old 08-02-2015, 06:27 PM
Yes, uve tried three different 1b3 tubes s and no change.
Old 08-04-2015, 09:13 PM
Did you check or replace the doorknob cap? That can load voltage down if leaking
Old 08-05-2015, 10:02 AM
I did a continuity check to see if shorted, but nothing. I don't have another to sub in to see if it's lesky. I believe it's the common 500mmf Orange cap.b I tried the set with it disconnected and no difference. Do you think that's it? Where can I find another?
Old 08-07-2015, 09:11 PM
Not sure I had high voltage taken away from doorknobs but I think if disconnected it would work if it was shorter. Try the fly replacement
