Old 07-01-2015, 08:54 PM
DavGoodlin's Avatar
Motorola Minion
RCA Victor 280 rescued at e-dump
I was there to drop off three CRT monitors, vintage because they were made in Japan and one was a Commodore. As I was pulling up to the loading area, a 6-legged lowboy appeared. Since this was an electronic waste facility, I went back to the office and asked if I could take the "wood item" away for them.
The manager agreed and I picked it up and noticed everything was there, even the wood veneer, some of which lifted. The tambour doors were open and they closed easily, revealing the correct finish color.
It had been in the weather as the cabinet needs both glue and finish restoration. It has some odd tubes for a 1933 model; PP 59 outputs, PP type 8 with interstage transformers. Ill post some pictures next,
-Dave G
Old 07-02-2015, 02:00 PM
DavGoodlin's Avatar
Motorola Minion
Camera is AWOL but here is the link to a 280 http://www.radioatticarchives.com/radio.htm?radio=5629 separate bass and treble in center, bandswitch above movie-dial and RF-amp bias level on left, labeled as "Supressor" that supplements the AVC
-Dave G
Last edited by DavGoodlin; 07-06-2015 at 02:22 PM. Reason: revise "range" to "supressor"
Old 07-02-2015, 04:48 PM
WISCOJIM WISCOJIM is offline
"movie-dial" on an RCA? I don't think so.
Old 07-03-2015, 01:54 AM
Rayburn69's Avatar
Rayburn69 Rayburn69 is offline
Good job!
Thank you for saving it- It deserves a better fate
Old 07-03-2015, 11:55 AM
DavGoodlin's Avatar
Motorola Minion
Well, I do have a GE H51 made by RCA and it does have the movie dial.
This RCA has a round conical dial that has the small window and Ill get a backlit photo of it.
I reattached loose veneer glued and clamped it last night. Id hate to cut some of those contours to match surrounding area using patches.
There is something really unique about this set so Ill put some early effort in. Its a good rescue job but a good bit of work also.
-Dave G
Old 07-03-2015, 12:03 PM
A backlit celluloid strip is not the same as a movie dial which has a projected image onto a frosted glass surface.
Old 07-03-2015, 12:11 PM
Originally Posted by DavGoodlin View Post
Camera is AWOL but here is the link to a 280 http://www.radioatticarchives.com/radio.htm?radio=5629 separate bass and treble in center, bandswitch above movie-dial and RF-amp bias level on left, labeled as "Range" that supplements the AVC
I looked it up on Nostalgia Air website. They only show the schematic and parts list.
A rather impressive set, to be sure. It must've been the TOTL that year.
I never seen 59's used much in RCA's. Zenith seemed to use them more.
Old 07-06-2015, 02:27 PM
DavGoodlin's Avatar
Motorola Minion
Re-attachment of veneer went well using pipe clamps. Some will need to be patched but all the funky contours were saved
Some wood-fill will be necessary and an overall stain will also be needed before lacquer is sprayed.
I should have some pics up soon.
-Dave G
Old 07-06-2015, 06:40 PM
TheShanMan's Avatar
TheShanMan TheShanMan is offline
Who in their right mind would recycle that??? Great save!
Old 07-06-2015, 09:09 PM
DavGoodlin's Avatar
Motorola Minion
Here it is as found - very soggy and some loose veneer on top
Working on a clampdown for saving the veneer
-Dave G
Old 07-07-2015, 05:31 AM
Kamakiri's Avatar
Kamakiri Kamakiri is offline
Ooooh that's nice!!
Old 07-07-2015, 07:56 AM
DavGoodlin's Avatar
Motorola Minion
There is something grand about those early 30s sets. I need to mention what was left behind and I regret not taking some photos of it.
A Bradford (sold by WT Grant stores) Color TV / Stereo console combination was also there. It was "weathered" as well.
A grand mediterranean cabinet with a 25" CRT and what appeared from the back cover to be an RCA clone chassis, the radio and TV controls were together under the right lid.
I once had a Muntz similarly equipped, but it was very compact and 6x9 speakers were on the sides of the single width cabinet.
They offered it to me also but I only had room in the truck for one treasure
-Dave G
Old 07-09-2015, 06:27 PM
radio63's Avatar
radio63 radio63 is offline
Still Y2K Compliant!
The RCA Victor Model 280 was one of RCA's top of the line models for 1933. It was advertised as a "12 tube Bi-Acoustic" receiver. It's a very impressive set. Can you imagine the history that was heard through this set? I hope to find a nice example some day.
Gilbert
I don't know anything about ignorance and I could care less about apathy.
www.galaxymoonbeamnightsite.com
