Old 07-23-2015, 05:40 PM
Console User Console User is offline
Can anyone tell me if either of the following 2 CRTs don't have the Yoke bonded to the CRT Neck?
A68ACT11X
A68ADT19X01
I am pretty sure the CRT that is currently in my TV which is A68ADT31X03 doesn't have a bonded yoke to the CRT? The parts list sheet for this TV shows the Yoke as a separate item from the CRT itself. Does anyone have any information to check and see if either of the 2 CRTs listed above would work in place of the current one? I asked the Seller of these CRTS for information and they never gave me any information on them.
Thanks.
Old 07-23-2015, 06:43 PM
Not by the book but turn brightness, color & contrast all the way down.
Adj G-2 up til you see retrace lines then turn down til they go away &
screen isnt lit.
Turn things back up & check that the brightness has good range.
For the color adjustments you need to get into the service menus.
ALLWAYS write down anything you change.
The red problem is probably a leaky driver or the CRT though.....
I have just noticed the red problem is more noticeable and stronger when trying to run the TV on Video. When running the Converter Box or Satellite Receiver on Ch.3/4 it's not nearly as bad.
Old 08-08-2015, 09:14 AM
When this TV has no Signal hooked up to it the TV is a True Black & White Snow that looks perfectly normal. However, when you hook up some type of signal whether it be satellite or antenna Converter Box the Back Screen shows too much Red color.
How do you access the Service Menu via the Remote to adjust the Color Bias on this TV?
