Old 12-09-2015, 08:23 PM
The B+ is 'waay too high, suggesting there's insufficient load to pull it down to spec. Likely the H.output stage is not conducting.
There's B+ on both sides of the fuse, right?
Since The damper is in series in the B+ pathway to the H.out stage, an open damper would cause your problem. Have you subbed the damper?
If so, with the set off, check for continuity from the fuse to pin 5 (plate) of the damper. Should be about 11 ohms.
Then check from pin 3 (cathode) of the damper to the plate of the H.out tube. Should be around 165 ohms.
Old 12-10-2015, 06:45 AM
Kamakiri's Avatar
Kamakiri Kamakiri is offline
So what voltage did you measure on C1, section C? What dc voltages do you measure on pins 2 and 5 of the 6SN7 horizontal oscillator tube?
First, I screwed up here and somehow measured voltages on the correct cap, but the wrong tube
Let's revise this one. Pin 2 has -30VDC, pin 5 has nothing.
Old 12-10-2015, 06:58 AM
Kamakiri's Avatar
B+ on both sides of the fuse, yes. Subbed the damper, both tubes tested good (both original and replacement), no changes.
continuity from the fuse to pin 5 (plate) of the damper. Should be about 11 ohms. Spot on.
Then check from pin 3 (cathode) of the damper to the plate of the H.out tube. Should be around 165 ohms. Zero.
Old 12-10-2015, 11:00 AM
Zero is very bad. Sounds like your flyback may have a shorted primary, although it seems unlikely that it would form a dead short? Possibly there's a wiring error? Try measuring directly across pins 1 and 2 of the fly transformer, there should be like 185 ohms.
Also you need to find out why there's no B+ getting to pin 5 of the horz osc tube. You should measure something like 75,070 ohms from the fuse to the 6SN7plate(pin 5).
Here's the horizontal section from my Admiral schematic. Easier to follow than the Sams, plus it has the voltages and resistances marked on it.
http://i452.photobucket.com/albums/q...pstvpvazop.jpg
Old 12-10-2015, 12:04 PM
By "zero" he probably means 'open'. There's also the H.linearity coil in series between the damper cathode and fly primary. The H.lin coil could be open.
Old 12-10-2015, 12:33 PM
Kamakiri's Avatar
You nailed that one. Sams shows it should read 36 ohms. Totally open. I think I have one from a parts chassis I can scrounge later.
Old 12-10-2015, 12:45 PM
The 6AS5 is used as a B+ dropper in lieu of a big fat resistor.
It's a sensible way to drop the B+, putting the otherwise wasted power to work. Cuts waste heat, and lessens the load on the power supply.
Old 12-10-2015, 01:17 PM
Oops, my bad. I always think infinity, but I should have read it in context of too high of B+.
Old 12-10-2015, 01:29 PM
Apparently it regulates well too.
Old 12-10-2015, 02:17 PM
Kamakiri's Avatar
Well, I nabbed a linearity coil out of a GE 810 chassis that I had here. It read 30 ohms versus the 36 in the Sams, but I figured that would get me a lot closer than an open coil would.
Sure enough, the horizontal oscillator started to run, and I got nice HV to the plate cap of the 1X2
No HV to the picture tube yet, but all that's left in that chain is a 1 meg resistor and a door knob cap.....both of which I should have in stock. Time for some more testing!!
Old 12-10-2015, 02:32 PM
Good goin' bro. Still kinda curious why there was no plate voltage on the H.osc before.Maybe there was a production change so it runs offa Boost instead of B+ (?)
Old 12-10-2015, 02:46 PM
Equally curious how the vertical Osc. was running before, with no boost.
Old 12-10-2015, 02:51 PM
Kamakiri's Avatar
Not sure, but I could hear it, and the frequency did change with the vertical hold.
Doorknob cap is fine, as is the 470 MOhm resistor on the 1X2 (Sams shows it to be a 1 Meg, but....anyway). Next, I'll clean the snot out of the tube pins and tube socket.
Old 12-10-2015, 02:57 PM
I guess Sams does show that some version had the V Osc. running off of B+. They show the alternative path with a dotted line.
470 M, as in mega ohms? Or is that the really really ancient abbreviation for one thousand?
Old 12-10-2015, 03:22 PM
Kamakiri's Avatar
470K. I typed it too fast
But hey! I gots a raster!!!!
I can barely get any sound at all on frequency and it looks like the IF's gonna need work, but this is a major leap forward, thanks to you guys!!!
Now, next question....source an Admiral replacement for that linearity coil, I assume?
