Old 01-10-2016, 01:11 PM
totem's Avatar
totem totem is offline
Toslink, HDMI to RCA
Seldom posting member on this side of AK, and I have a question or two.
I have a Panasonic plasma that I wanted to run audio out to a Linn amp with RCA in only, the TV has an optical out in addition to HDMI.
I picked up an optical to RCA converter and connected it, the optical connection to the TV did not seem to engage as well as the opposite end into the converter, tried various orientations etc.
I thought an optical connection was universal in shape?
Although I do get an audio signal to the amp the output is much lower than
any other source into the amp.
Is this typical of using an optical to RCA converter?
The other option I hadn't considered at the time was to try the HDMI out to RCA into the amp.
Is there a particular HDMI to RCA converter needed? Or simply an HDMI to RCA cable interface.
Rick
Analog guy in a digital world.
I'm wearing the same skin, I take it all on the chin.
Old 01-10-2016, 01:57 PM
miniman82's Avatar
First Light: 1952-2011
I got an HDMI>NTSC converter at a garage sale for $5, still have to try it out though. Maybe the TV doesn't automatically convert to optical audio out, are there other outputs you can use?
Evolution...
Old 01-10-2016, 03:12 PM
KentTeffeteller's Avatar
Gimpus Stereophilus!
Big issue with HDMI often is HDCP (High Definition Content Protection) handshake issues.
Old 01-11-2016, 02:22 PM
Old 01-11-2016, 02:24 PM
lnx64's Avatar
lnx64 lnx64 is offline
If you are using this link for audio output, make sure the TV settings for this link are pcm. Most of these converters do not do dd or dts.
