Old 01-15-2016, 10:17 AM
Kamakiri's Avatar
Kamakiri Kamakiri is offline
Funky funky issue with a CTC-58 XL-100
Picked up this set from a local collector, who shot this video. I've never seen an issue like this before, take a look:
https://www.youtube.com/watch?v=nGyboqrG8ic
Swapped vertical boards out of another set, and that's not it. About all I can think of is a regulation issue. There's a 470 uF cap on the board which I've heard is problematic, so I'm going to replace that.
Before I finish up my Mouser order, any thoughts or input?
Old 01-15-2016, 11:07 AM
Old 01-15-2016, 01:51 PM
A few things to watch on early XL100's
Cold joints around the pin transformer.
Cold grounds from main chassis to mother board.
Module sockets crack & go int.
If any of these it should act up when tapping around.
On the 17" sets vert sockets were a BIG problem. They
would crack & cause the module PCB to burn up.
New socket & a module with no dud value was costly.
If none of that start with 'lytics from the output then
back.
Old 01-15-2016, 04:30 PM
I've seen that before but i can't remember when, looks like a bad filter somewhere.
I'd try jumping the filter caps (set off) one at a time and see if it goes away.
