Old 05-22-2016, 04:05 PM
rca2000's Avatar
rca2000 rca2000 is offline
WHY are electrostatic tubes wired so WEIRD?
Looking at the diagram of my 48-700, 50-701 and other Electrostatic-Deflect. type sets...It seems to ME...that the CRT in ALL of them is set up in a STRANGE way..
There does NOT appear to be a "2nd anode", at least in the way we are used to in most other tubes. like a 12LP4, 21AXP22, and about any M-D tube I have ever seen. . And WHY...does the HV seem to go to the CATHODE of the CRT--I am used to VIDEO being there--and at the most 250 volts or so. On E-D tubes...the HV, through some resistors seems to end up there!!
WHY...is this????
Old 05-22-2016, 05:37 PM
N2IXK's Avatar
N2IXK N2IXK is offline
Technohippie
They do it to place the deflection plates closer to ground potential, to simplify the deflection amplifier design. They apply a NEGATIVE high voltage to the cathode end of the gun, which is effectively the same as a high POSITIVE voltage at the anode end of the gun.
Old 05-22-2016, 06:02 PM
This is (was?) a common arrangement for oscilloscopes.
Old 05-22-2016, 09:22 PM
miniman82's Avatar
First Light: 1952-2011
Easier electrically to lower the cathode than it is to raise all the deflection plates.
Evolution...
Old 05-22-2016, 09:57 PM
Yet in other topologies like the Motorola VT-73, they do raise all the deflection plates with positive HV while keeping the cathode end of the jug 'conventional'.
http://www.earlytelevision.org/pdf/M...Sams-71-12.pdf
Old 05-23-2016, 05:11 PM
miniman82's Avatar
In scopes it was advantageous to have the high sensitivity deflection plates at or near ground, I suspect to avoid noise. TV's it's not an issue, those tubes probably aren't near as sensitive.
Evolution...
Old 05-23-2016, 05:32 PM
Plus it would be undesirable to have the usual hv decoupling caps in series with the deflection plates if decent low frequency (or dc) response is desired.
