Old 07-22-2016, 10:44 PM
Have you verified that everything in the Horizontal hold circuit is good?
Old 07-22-2016, 10:49 PM
Could you be more specific as to what you mean by good? I replaced all the caps and resistors in the circuit. I have will go back and check to see if I made a mistake replacing those caps and resistors.
Old 07-23-2016, 01:35 AM
My friend emailed and said to turn the H. Frequency adjustment CCW. It has a wide range. Bingo.
I'll have to put in the 16KP4 tube next to see what it'll really look like.
Old 07-23-2016, 08:02 AM
This morning I removed the focus coil off the test CRT. Much better. I'll do some voltage checks and replace the selenium rectifier today. The picture is actually much better in person than the photo.
Old 07-23-2016, 09:41 AM
Getting better. Here is small clip from White Christmas. With the 16" CRT.
https://youtu.be/5KVM0_c8l4Q
Old 07-23-2016, 10:20 AM
The set is in brand-new condition, a real labor of love.
Great to see the CRT is that good.
Old 07-23-2016, 09:22 PM
Thanks for the kind words.
Old 07-23-2016, 09:24 PM
I did some more work on getting it done. It is pretty much finished. I have a few details I need to work on. I also want to go through the alignment procedure so I can learn about it. Here the pics.
Old 07-23-2016, 10:18 PM
Nice, tidy work. You have made great progress.
Are you using a VCR as a source? The bending near the top of the screen is classic VCR distortion. Many, many vintage TVs have this issue, although they will display perfectly with a DVD player or other non-videotape source.
Phil Nelson
Phil's Old Radios
Old 07-23-2016, 11:44 PM
Phil,
Yup a VCR. I'll try out my DVD player. Thanks for the tip and kind words.
I almost forgot I wanted to glue the CRT base back on. It was just a little loose. I use some glue I got at Walmart labeled E6000. It's high heat, flexible, and bonds glass to plastic and such. I squeeze out some in a small mixing container and add some acetone. I mix it up thoroughly to the consistency of syrup. I then suspend the CRT facing up and "trowel" the glue where the base meets the glass CRT with a round toothpick. I go around the perimeter of the base and as the glue seeps down into the base, I add more glue. When satisfied, I wipe down both the base and the CRT with some acetone. I'll let it dry overnight.
Old 07-24-2016, 07:16 AM
60s Throwback
Wow, top notch work!!
Old 07-25-2016, 11:51 AM
OK, I aligned the video and sound IF using my signal generator and VTVM. I have a good picture and great audio.
I do have some little white bars that go across the top of the screen. See attached picture. Any ideas?
Old 07-25-2016, 12:30 PM
MRX37 MRX37 is offline
Those white lines are very likely from your video source.
Old 07-25-2016, 01:51 PM
They are either closed captioning (which lurks at the extreme top of the frame), or macrovision copy protection (which usually droops down lower).
If you have Cable/Satellite you should watch the AMC channel on your AMC TV set at least once.
