Old 10-15-2016, 02:17 PM
pac.attack76's Avatar
Stuck in the past
The Zenith/Bose set with chinese cabinet
Deciding whether or not to fix. Fired it up for the first time since I picked it up. After running awhile, didn't look to bad. Sound was good. Pic is raised from the bottom and top is stretched. Is there a certain set of caps I need or will I have to just check to see? Anything else an issue?
Genesis does what Nintendon't
Old 10-15-2016, 03:00 PM
dishdude's Avatar
dishdude dishdude is offline
That's sweet. Definitely fix it. Unique cabinet, Bose...that's a rare set.
Old 10-15-2016, 03:12 PM
Jon A.'s Avatar
Jon A. Jon A. is offline
Don't mess with Esther.
Yah, that's a keeper. Probably a simple fix.
Old 10-15-2016, 06:22 PM
TVTim's Avatar
TVTim TVTim is offline
I like it. Unique. Try to get it repaired.
Old 10-15-2016, 06:36 PM
Change EVERY electrolytic cap on the vert module & check for
cold joints. The vert IC has been NLA for yrs so you dont
want it to blow over a few bucks worth of caps!
Also go over the power supply & HV modules for cold joints &
swollen 'lytics.
CRT looks fair with some red bleeding. Running it & adjusting
it "down" a little will help.
This is a "Digital System 3". after the video detector everything
is digitalized for processing. This model is VERY rare & the
most expensive in the line. If a 27" would have been $1,500- $2000.
A non Bose 27" table model DS3 was $1000......
Please keep it & keep it intact !!!!
BTW "digital" sets like this using the ITT chip set were also sold by
NEC, Toshiba Panasonic & maybe MGA. Zenith sold by far the
most from 20" to projection sets.
Old 10-15-2016, 10:21 PM
Stuck in the past
I'll definitely be fixing then. Soon as I get into it, ill go over everything.
Old 10-16-2016, 12:16 AM
Looks like pincushion issues too.
Old 10-16-2016, 10:22 AM
Old 05-20-2017, 10:18 PM
Stuck in the past
With so many projects, I'm just now getting around to this one. September 1986 model. I took these three pics. If anyone can point me in the right direction of what needs replacing and what needs touching up. One will be checking under the plate below for caps, etc. Not sure where the vertices section is on this one.
Old 05-21-2017, 11:40 AM
