Old 12-22-2016, 03:58 PM
Anything in 30% tolerance is fine/normal in most sets. You may have touched the wrong damper pin...One normally has meter killing HV on it.
Old 12-22-2016, 05:37 PM
You'd think the kit maker woulda pasted on a hazard warning in big red letters "Do not attempt to measure plate of H.out tube or cathode of damper tube", since there's a very high level spike there.
Old 12-22-2016, 09:00 PM
I hear ya! My inexperience showed up on that one. The schematic shows to have 350 volts on pin 3 of V13 12AX4 the Damper tube.
Still a bit puzzled as to why that would happen and especially when the schematic says 350 volts.
Old 12-22-2016, 09:02 PM
I thought I'd try direct video injection. I injected the video signal directly into pin 2 of the 12BY7A amp. The picture got only slightly better, but still way out of focus.
Old 12-22-2016, 09:14 PM
What voltage do you have on G2?
Old 12-22-2016, 09:16 PM
Which tube? On the CRT G2 is pin 10 and that has 301 volts as I let the TV play right now.
Old 12-22-2016, 09:29 PM
Another thought just occurred to me. When I was doing the voltage checks, the tubes were installed. Could the 350 volt marking on the schematic meant with the tubes removed? Though I don't see how you can get some voltages without them being installed. Just thinking out loud.
Old 12-22-2016, 10:22 PM
Well, if the 12AX4 were removed, you wouldn't have any voltage on pin 3 (cathode) because it would break the DC current pathway for B+ to the rest of the H.sweep circuit. (Besides, with the tube removed, the other tubes won't light because it's a series heater string.)
The 350V is the raw, unfiltered B Boost voltage, and you sure as heck don't want to measure it at the damper cathode (!). If the kit maker actually measured it there, they were using a beefy old analog meter with mechanical movement that smoothed out the high level spike. And they were highly negligent in not posting a hazard warning.
Old 12-23-2016, 12:00 AM
...This is an aluminized tube so no ION Trap.
Just because it's aluminized doesn't mean it doesn't need an ion trap magnet. The data sheet says you need a single ion trap magnet. Don't see any exception mentioned for the "C" version. Also is it a rebuild ? If so, it might have a straight or bent gun.
Old 12-23-2016, 12:07 AM
Bob, yes it is a rebuild. It does have a straight gun and it has 2 labels warning not to use an ION trap.
Old 12-23-2016, 12:14 AM
OK, they sure made that clear! I'm out of ideas except low HV.
Old 12-23-2016, 12:24 AM
Appreciate the help and your videos.
Old 12-23-2016, 08:17 AM
At the suggestion of someone, I wired in a 2 meg pot to take the focus electrode, pin 6 of the CRT, from ground to 300 volts. I did and that didn't help at all. I also checked to be sure I had continuity from the CRT harness to the CRT base when the connector was plugged to the CRT. That checked good.
Maybe a broken focus wire from the base to the bulb?
Old 12-23-2016, 10:04 AM
I've seen the e'stat tubes focus well without anything connected to pin 6.
Being a newcomer to the hobby, you don't have access to any of the junk us collectors have, such as another, smaller CRT or maybe a magnetic focus unit.
I know, the gun structure is different on a e'stat focus tube but maybe a magnetic focalizer would help.
BTW, that's the focus look like on the 5AXP4 test tube.
Old 12-23-2016, 07:09 PM
The focus on the 5AXP4 is much better.
